2006-11-15 | GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff | Ralf Corsepius | 2 | -4/+4 | |
2006-11-15 | Remove (Obsolete) | Ralf Corsepius | 2 | -6221/+0 | |
2006-11-15 | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+8 | |
* patches/gcc-core-4.2-20061114-rtems4.8-20061115.diff: New. * patches/newlib-1.14.0-bfinrtems-20060810a.diff: Remove (Obsolete). * patches/gcc-4.1.1-bfinrtems-20060810a.diff: Remove (Obsolete). * rtems-4.8/bfin/Makefile.am, rtems-4.8/bin/gcc-sources.add: GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff. | |||||
2006-11-15 | New. | Ralf Corsepius | 1 | -0/+17745 | |
2006-11-14 | Add. | Ralf Corsepius | 1 | -0/+556 | |
2006-11-10 | 'BR: flex bison' for gcc >= 4.2.0 | Ralf Corsepius | 1 | -0/+3 | |
2006-11-09 | Introduce GCC_PKGVERS | Ralf Corsepius | 16 | -15/+25 | |
2006-11-09 | Upgrade to gcc-4.2.0-20061031. | Ralf Corsepius | 1 | -2/+7 | |
2006-11-09 | New (Merge BFIN patches). | Ralf Corsepius | 2 | -0/+5137 | |
2006-10-30 | Update sparc dep to rtems4.8 | Ralf Corsepius | 1 | -1/+1 | |
2006-10-27 | Remove (unused) | Ralf Corsepius | 3 | -738/+0 | |
2006-10-27 | Remove (unused). | Ralf Corsepius | 1 | -3699/+0 | |
2006-10-27 | Remove (broken). | Ralf Corsepius | 1 | -4138/+0 | |
2006-10-27 | Remove (obsolete). | Ralf Corsepius | 1 | -838/+0 | |
2006-10-27 | 2006-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac, Makefile.am: Remove rtems4.7. * rtems4.7: Remove (Development now in rtems-4-7-branch only). | |||||
2006-10-27 | Remove rtems-4.7 | Ralf Corsepius | 2 | -14/+0 | |
2006-10-27 | Remove (unused). | Ralf Corsepius | 59 | -866/+0 | |
2006-10-27 | Bump GCC_RPMREL. | Ralf Corsepius | 11 | -11/+11 | |
* patches/newlib-1.14.0-rtems4.8-20061027.diff: New. * patches/newlib-1.14.0-rtems-20061026.diff: Remove (broken). | |||||
2006-10-27 | Update to newlib-1.14.0-rtems4.8-20061027.diff | Ralf Corsepius | 11 | -11/+11 | |
2006-10-27 | New. | Ralf Corsepius | 1 | -0/+4120 | |
2006-10-26 | 2006-10-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+4142 | |
* patches/newlib-1.14.0-rtems-20061026.diff: New file. | |||||
2006-10-25 | Let rtems-@RTEMS_API@-repo-conf.spec depend on configure.ac | Ralf Corsepius | 1 | -1/+1 | |
2006-10-25 | Bumb version to 0.4 | Ralf Corsepius | 1 | -1/+1 | |
2006-10-24 | Bump version to 0.3 | Ralf Corsepius | 1 | -1/+1 | |
2006-10-24 | New URL ftp://ftp.rtems.org/pub/rtems/linux | Ralf Corsepius | 2 | -6/+6 | |
2006-10-24 | Cleanup. | Ralf Corsepius | 1 | -19/+0 | |
2006-10-22 | 2006-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am, configure.ac: Add rtems-4.8. | |||||
2006-10-22 | Add rtems-4.8 | Ralf Corsepius | 2 | -1/+15 | |
2006-10-21 | Reset RPMRELs = 1 | Ralf Corsepius | 11 | -30/+30 | |
2006-10-21 | Abandon binutils-2.16*. Apply binutils-2.17-rtems4.8-20061021.diff | Ralf Corsepius | 11 | -26/+20 | |
2006-10-21 | New. | Ralf Corsepius | 64 | -0/+942 | |
2006-10-21 | Remove (Unsupported) | Ralf Corsepius | 5 | -78/+0 | |
2006-10-21 | Sync with rtems-4-7-branch | Ralf Corsepius | 22 | -34/+33 | |
2006-10-21 | New. | Ralf Corsepius | 1 | -0/+1 | |
2006-10-21 | Let config.status generate rtems-@RTEMS_API@-repo-conf.spec | Ralf Corsepius | 1 | -3/+1 | |
2006-10-21 | Use @PACKAGE_TARNAME@ | Ralf Corsepius | 1 | -1/+1 | |
2006-10-21 | Add missing backslash | Ralf Corsepius | 1 | -1/+1 | |
2006-10-21 | Add myself. | Ralf Corsepius | 1 | -0/+1 | |
2006-10-21 | New. | Ralf Corsepius | 17 | -0/+813 | |
2006-10-19 | Cleanup. | Ralf Corsepius | 1 | -3/+1 | |
2006-10-19 | Remove. | Ralf Corsepius | 1 | -60/+0 | |
2006-10-19 | Bump GCC_RPMREL | Ralf Corsepius | 2 | -2/+2 | |
2006-10-19 | rtems-4.7-h8300-rtems4.7-gcc-4.1.1-5 | Ralf Corsepius | 1 | -2/+2 | |
2006-10-19 | rtems-4.7-avr-rtems4.7-gcc-4.0.3-2 | Ralf Corsepius | 1 | -2/+2 | |
2006-10-16 | 2006-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Set RTEMS_API to 4.8. | |||||
2006-10-16 | 2006-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -10/+18 | |
* autotools/Makefile.am, autotools/automake.add: Update to automake-1.10. | |||||
2006-09-13 | New. | Ralf Corsepius | 2 | -0/+3824 | |
2006-09-08 | New file. | Joel Sherrill | 1 | -0/+35 | |
2006-09-03 | Default to not building bsps. Too many problems. | Chris Johns | 2 | -10/+15 | |
