path: root/contrib/solaris (follow)
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-242-1/+5
| | | | * configure.ac: Require automake > 1.9.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-1/+4
| | | | * Makefile.am: Cosmetics.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-4/+5
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-283-4/+16
| | | | | * setup.def, sparc-solaris-gcc.spec.in: Update and enable gnat. You must build and install a C only toolset first though.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-271-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * setup.def, sparc-solaris-binutils.spec.in: Updated and used to build sparc-solaris 3.2.1-1 C language only. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2001-04-16 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Added missing files. * setup.def: New shot using gcc 3.0.4 RPMs. * sparc-solaris-binutils.spec.in: Switched to bz2 file. * sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive and use find to pick up all files. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-02-08 Joel Sherrill <joel@OARcorp.com> * .cvsignore: New file. 2001-02-05 Joel Sherrill <joel@OARcorp.com> * Makefile.am: New file, missed previously. 2004-02-05 Joel Sherrill <joel@OARcorp.com> * ChangeLog, configure.ac, setup, setup.def, sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in, sparc-solaris-libs.spec.in: New files.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-272-5/+10
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-165-39/+27
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+9
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-082-0/+10
| | | | | | | | | | | | | * Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused with RTEMS. * r46kstub.c: Renamed to mips-stub.c. * mips-stub.c: New file -- was r46kstub.c. * memlimits.h: New file was limits.h. * limits.h: Removed. * r4600.h: Eliminated need for this file. * README: Updated. * gdb_if.h: Added CVS Id. * mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+26
* 2004-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-057-0/+429
