path: root/contrib/solaris/sparc-solaris-binutils.spec.in (follow)
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-271-5/+5
| | | | | | * setup.def, sparc-solaris-binutils.spec.in: Updated and used to build sparc-solaris 3.2.1-1 C language only.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-161-1/+1
| | | | | | | | * .cvsignore: Added missing files. * setup.def: New shot using gcc 3.0.4 RPMs. * sparc-solaris-binutils.spec.in: Switched to bz2 file. * sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive and use find to pick up all files.
* 2004-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-051-0/+86
* ChangeLog, configure.ac, setup, setup.def, sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in, sparc-solaris-libs.spec.in: New files.
