* .cvsignore: Add install-sh and missing.
* Makefile.am: Cosmetics.
* setup.def, sparc-solaris-gcc.spec.in: Update and enable gnat. You
must build and install a C only toolset first though.
* setup.def, sparc-solaris-binutils.spec.in: Updated and
used to build sparc-solaris 3.2.1-1 C language only.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Added missing files.
* setup.def: New shot using gcc 3.0.4 RPMs.
* sparc-solaris-binutils.spec.in: Switched to bz2 file.
* sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive
and use find to pick up all files.
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused
with RTEMS.
* r46kstub.c: Renamed to mips-stub.c.
* mips-stub.c: New file -- was r46kstub.c.
* memlimits.h: New file was limits.h.
* limits.h: Removed.
* r4600.h: Eliminated need for this file.
* README: Updated.
* gdb_if.h: Added CVS Id.
* mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* Makefile.am: New file, missed previously.
2004-02-05 Joel Sherrill <joel@OARcorp.com>
* ChangeLog, configure.ac, setup, setup.def,
sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in,
sparc-solaris-libs.spec.in: New files.
