* | 2001-04-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-16 | 1 | -0/+4 |
| | | | | | | | | * .cvsignore: Added missing files. * setup.def: New shot using gcc 3.0.4 RPMs. * sparc-solaris-binutils.spec.in: Switched to bz2 file. * sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive and use find to pick up all files. | ||||
* | 2002-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-08 | 1 | -0/+6 |
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused with RTEMS. * r46kstub.c: Renamed to mips-stub.c. * mips-stub.c: New file -- was r46kstub.c. * memlimits.h: New file was limits.h. * limits.h: Removed. * r4600.h: Eliminated need for this file. * README: Updated. * gdb_if.h: Added CVS Id. * mips-stub.c: Attempt to deal with MIPS1 versus MIPS3. |
