* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-21 | 2 | -1/+4 |
| | | | | * rtems.spec.in: Remove more ITRON references. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -1/+5 |
| | | | | * AUTHORS: Convert to UNIX CR/LF style. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | Default to not building bsps. Too many problems. | Chris Johns | 2006-09-03 | 2 | -10/+15 |
* | Change the rpm to use the version. | Chris Johns | 2006-08-22 | 1 | -4/+5 |
* | Add a version for rtems. | Chris Johns | 2006-08-22 | 1 | -6/+22 |
| | | | | Add checking messages. | ||||
* | Renamed the spec file. | Chris Johns | 2006-08-18 | 2 | -8/+6 |
* | Updated the specs file. | Chris Johns | 2006-08-18 | 1 | -0/+110 |
* | Move to rtems.specs.in. | Chris Johns | 2006-08-17 | 1 | -111/+0 |
* | Add the rtemsrpms package to RTEMS. | Chris Johns | 2006-08-17 | 11 | -0/+822 |
