* rtems_logo.bmp: Clipped to get the correct proportions
in the installer's header.
* upload.sh: Install only the specific build installers.
* rtems.ini: Change to show the actual web paths.
* version: Build 15.
* build-exes.sh, msys-path.nsi, rtems-autotools.nsi,
rtems-tools.nsi: Fixed MSYS path detection. Fixed the uninstaller
registry data. Changed the way the top level is generated. Now all
the sections are added no matter what target is specified.
* README, build-rpms.sh, rtems.ini, build-exes.sh,
rtems-tools.nsi: Updated to the new 4.8 build plus a new
installer.
* autoconf.def, automake.def, ba-wrap.sh, build-autotools.sh,
msys-path.nsi, rtems-autotools.nsi, target-section-text,
upload.sh, version: New to version 4.8. Autotools is built when
installing.
