2013-03-12 | contrib: Remove. | Joel Sherrill | 1 | -281/+0 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -0/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2007-07-28 | 2007-07-28 Chris Johns <chisj@rtems.org> | Chris Johns | 1 | -0/+281 | |
* README, build-rpms.sh, rtems.ini, build-exes.sh, rtems-tools.nsi: Updated to the new 4.8 build plus a new installer. * autoconf.def, automake.def, ba-wrap.sh, build-autotools.sh, msys-path.nsi, rtems-autotools.nsi, target-section-text, upload.sh, version: New to version 4.8. Autotools is built when installing. |
