path: root/contrib/cygwin (follow)
* 2006-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-01-082-0/+6
| | | | * .cvsignore: Add install-sh and missing.
* Cosmetics.Ralf Corsepius2004-12-301-1/+2
* 2004-11-05 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-0515-363/+462
| | | | | | | | | | | * i686-pc-cygwin-binutils.spec.in, i686-pc-cygwin-gcc.spec.in, i686-pc-cygwin-libs.spec.in, i686-pc-cygwin-mingw.spec.in, i686-pc-cygwin-w32api.spec.in: New. * i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in: Remove. * setup.def: Update to current cygwin. * Makefile.am, configure.ac: Reflect changes above.
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-242-1/+5
| | | | * configure.ac: Require automake > 1.9.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-1/+4
| | | | * Makefile.am: Cosmetics.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-7/+6
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-072-31/+47
| | | | | | | * i386-cygwin-gcc.spec.in: Use %_prefix instead of %prefix. Add gnatlib. Add %defattr(-,root,root). Provide virtual packages i386-cygwin-[c++|g++|gnat].
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-282-0/+10
| | | | * .cvsignore: Add entries to .cvsignore.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-273-2/+13
| | | | | | * i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for revision 2.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-274-18/+20
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def: Updated to current Cygwin versions and fixed some minor nits in the specifications. 2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * setup.def: Update to binutils-20021117-1. * i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1. Adaptations to RH-8.0/rpm-4.1. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. 2001-02-05 Joel Sherrill <joel@OARcorp.com> * i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in: Modified group. 2001-01-22 Joel Sherrill <joel@OARcorp.com> * i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest versions and packaging. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-09-13 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Corrected for missing files. 2001-08-31 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Missed in previous commit. 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def: New files that support building RPMs for Linux hosted cross compilers targeting Cygwin.
* 2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-163-7/+15
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+9
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-3/+8
* 2001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-227-11/+18
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+80
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-78/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-1/+8
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-132-1/+10
* 2001-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-311-0/+4
* 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-08-3110-0/+565
