path: root/contrib/cygwin (follow)
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+80
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-78/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-1/+8
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-132-1/+10
| | | | * .cvsignore: Corrected for missing files.
* 2001-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-311-0/+4
| | | | * .cvsignore: Missed in previous commit.
* 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-08-3110-0/+565
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def: New files that support building RPMs for Linux hosted cross compilers targeting Cygwin.
