* i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Modified group.
* i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in,
i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest
versions and packaging.
* configure.in: Remove.
* .cvsignore: Corrected for missing files.
* .cvsignore: Missed in previous commit.
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in,
i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in,
i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def:
New files that support building RPMs for Linux hosted cross compilers
targeting Cygwin.
