* i686-pc-cygwin-binutils.spec.in, i686-pc-cygwin-gcc.spec.in,
i686-pc-cygwin-libs.spec.in, i686-pc-cygwin-mingw.spec.in,
i686-pc-cygwin-w32api.spec.in: New.
* i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in,
i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Remove.
* setup.def: Update to current cygwin.
* Makefile.am, configure.ac: Reflect changes above.
* i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for
revision 2.
* i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def:
Updated to current Cygwin versions and fixed some minor nits in
the specifications.
2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* setup.def: Update to binutils-20021117-1.
* i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1.
Adaptations to RH-8.0/rpm-4.1.
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2001-02-05 Joel Sherrill <joel@OARcorp.com>
* i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Modified group.
2001-01-22 Joel Sherrill <joel@OARcorp.com>
i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest
versions and packaging.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-13 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Corrected for missing files.
2001-08-31 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Missed in previous commit.
2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in,
i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in,
i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def:
New files that support building RPMs for Linux hosted cross compilers
targeting Cygwin.
targeting Cygwin.
