path: root/contrib/cygwin/i386-cygwin-w32api.spec.in (follow)
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-051-1/+1
| | | | | * i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in: Modified group.
* 2001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-221-1/+1
| | | | | | | * i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest versions and packaging.
* 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-08-311-0/+47
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def: New files that support building RPMs for Linux hosted cross compilers targeting Cygwin.
