* | 2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-16 | 1 | -6/+8 |
| | | | | | | * setup.def: Update to binutils-20021117-1. * i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1. Adaptations to RH-8.0/rpm-4.1. | ||||
* | 2001-01-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-22 | 1 | -1/+1 |
| | | | | | | | * i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest versions and packaging. | ||||
* | 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-08-31 | 1 | -0/+86 |
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def: New files that support building RPMs for Linux hosted cross compilers targeting Cygwin. |
