2012-02-17 | Remove (Moved to git.rtems.org/data/git/rtems-crossrpms.git). | Ralf Corsépius | 395 | -79724/+0 | |
2012-02-08 | Remove (Obsolete). | Ralf Corsépius | 1 | -497/+0 | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | 36 | -136/+0 | |
2011-12-14 | Regenerate. | Ralf Corsepius | 16 | -32/+144 | |
2011-12-14 | Bump GDB_RPMREL. | Ralf Corsepius | 16 | -16/+16 | |
2011-12-14 | Disable system-readline on EL5 with gdb >= 7.3.91. | Ralf Corsepius | 1 | -1/+8 | |
2011-12-14 | readline-6.1.2-2. | Ralf Corsepius | 3 | -7/+7 | |
2011-12-13 | Work-around gdb-7.3.91 bug. | Ralf Corsepius | 1 | -0/+6 | |
2011-12-13 | Regenerate. | Ralf Corsepius | 16 | -36/+202 | |
2011-12-13 | gdb-7.3.91. | Ralf Corsepius | 32 | -20/+90 | |
2011-12-13 | New. | Ralf Corsepius | 1 | -0/+417 | |
2011-12-12 | Regenerate. | Ralf Corsepius | 1 | -1/+2 | |
2011-12-12 | Adjust Source0. | Ralf Corsepius | 1 | -1/+2 | |
2011-12-12 | Regenerate. | Ralf Corsepius | 2 | -9/+20 | |
2011-12-12 | Bump AUTOCONF_RPMREL. | Ralf Corsepius | 1 | -3/+3 | |
Update to automake-1.11.1b. | |||||
2011-12-12 | Fix perl module filtering. | Ralf Corsepius | 2 | -5/+16 | |
2011-11-24 | Regenerate. | Ralf Corsepius | 15 | -106/+107 | |
2011-11-24 | GCC_RPMREL = 4 | Ralf Corsepius | 13 | -13/+13 | |
2011-11-24 | gcc-core-4.6.2-rtems4.11-20111124.diff. | Ralf Corsepius | 15 | -15/+15 | |
2011-11-24 | New. | Ralf Corsepius | 1 | -0/+582 | |
2011-11-24 | Regenerate. | Ralf Corsepius | 1 | -7/+4 | |
2011-11-24 | binutils-2.22, gcc-4.4.6 | Ralf Corsepius | 1 | -4/+4 | |
2011-11-23 | Regenerate. | Ralf Corsepius | 6 | -24/+24 | |
2011-11-23 | binutils-2.22. | Ralf Corsepius | 6 | -12/+12 | |
2011-11-22 | Regenerate. | Ralf Corsepius | 15 | -45/+45 | |
2011-11-22 | binutils-2.22. | Ralf Corsepius | 15 | -15/+15 | |
2011-11-18 | Regenerate. | Ralf Corsepius | 14 | -98/+112 | |
2011-11-18 | Bump GCC_RPMREL. | Ralf Corsepius | 15 | -15/+15 | |
2011-11-18 | BR: cloog-devel, ppl-devel for suse12_1. | Ralf Corsepius | 1 | -0/+1 | |
2011-11-16 | Regenerate. | Ralf Corsepius | 6 | -60/+72 | |
2011-11-16 | Abandon gcc-4.5.0. | Ralf Corsepius | 6 | -18/+0 | |
2011-11-16 | GCC_RPMREL = 0.20110802.0 | Ralf Corsepius | 6 | -6/+6 | |
2011-11-15 | Regenerate. | Ralf Corsepius | 15 | -105/+195 | |
2011-11-15 | Bump GCC_RPMREL. | Ralf Corsepius | 15 | -15/+15 | |
2011-11-15 | Preps for suse-12.1 | Ralf Corsepius | 1 | -0/+6 | |
2011-10-30 | New. | Ralf Corsepius | 1 | -0/+559 | |
2011-10-28 | Regenerate. | Ralf Corsepius | 15 | -172/+172 | |
2011-10-28 | Preps for gcc-4.6.2. | Ralf Corsepius | 28 | -84/+93 | |
2011-10-06 | Regenerate. | Ralf Corsepius | 15 | -120/+120 | |
2011-10-06 | newlib-1.19.0-rtems4.11-20111006.diff | Ralf Corsepius | 15 | -15/+15 | |
2011-10-06 | Bump GCC_RPMREL. | Ralf Corsepius | 15 | -15/+15 | |
2011-10-06 | New. | Ralf Corsepius | 1 | -0/+6336 | |
2011-09-28 | Housekeeping. | Ralf Corsepius | 3 | -11340/+0 | |
2011-09-05 | Regenerate. | Ralf Corsepius | 16 | -140/+144 | |
2011-09-05 | Bump GCC_RPMREL. | Ralf Corsepius | 15 | -15/+15 | |
2011-09-05 | gcc-core-4.5.3-rtems4.11-20110905.diff, gcc-g++-4.5.3-rtems4.11-20110905.diff | Ralf Corsepius | 15 | -30/+30 | |
2011-09-05 | New. | Ralf Corsepius | 2 | -0/+6373 | |
2011-09-05 | Restore bfin hacks. | Ralf Corsepius | 1 | -4/+9 | |
2011-09-05 | Regenerate. | Ralf Corsepius | 16 | -16/+16 | |
2011-09-05 | Fix typo | Ralf Corsepius | 16 | -16/+16 | |
