* | Remove newlib/libc/include/sched.h | Ralf Corsepius | 2009-02-06 | 1 | -0/+318 | |
* | Regenerate. | Ralf Corsepius | 2009-02-06 | 12 | -118/+592 | |
* | newlib-1.17.0-rtems4.10-20090206.diff | Ralf Corsepius | 2009-02-06 | 12 | -12/+12 | |
* | Rework. | Ralf Corsepius | 2009-02-06 | 4 | -11/+12 | |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-06 | 12 | -48/+48 | |
| | | | | Rework CPUKIT*. | |||||
* | Regenerate. | Ralf Corsepius | 2009-02-03 | 12 | -58/+58 | |
* | Bump GCC_RPMREL, NEWLIB_RPMREL to rebuild against binutils-2.19.1 | Ralf Corsepius | 2009-02-03 | 12 | -24/+24 | |
* | New. | Ralf Corsepius | 2009-02-03 | 1 | -0/+44 | |
* | Upgrade to binutils-2.19.1 | Ralf Corsepius | 2009-02-03 | 36 | -120/+120 | |
* | Regenerate. | Ralf Corsepius | 2009-02-03 | 12 | -82/+70 | |
* | Fix typo. | Ralf Corsepius | 2009-02-03 | 1 | -1/+1 | |
* | newlib-1.17.0-rtems4.10-20090203.diff | Ralf Corsepius | 2009-02-03 | 12 | -12/+12 | |
* | sys/param.h: Acknowledge -D_KERNEL. Do not include ucred.h. | Ralf Corsepius | 2009-02-03 | 1 | -0/+300 | |
| | | | | Incorporate newlib inttypes.h changes. | |||||
* | Eliminate %{newlib_release}. | Ralf Corsepius | 2009-02-03 | 4 | -6/+5 | |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-03 | 12 | -24/+24 | |
* | Regenerate. | Ralf Corsepius | 2009-01-26 | 13 | -104/+130 | |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-01-26 | 13 | -13/+13 | |
* | Abandon SuSE < 10.3 | Ralf Corsepius | 2009-01-26 | 1 | -6/+2 | |
* | Add Cdn-X hacks. | Ralf Corsepius | 2009-01-26 | 1 | -1/+7 | |
* | Regenerate. | Ralf Corsepius | 2009-01-26 | 12 | -92/+85 | |
* | Upgrade to gcc-4.3.3 | Ralf Corsepius | 2009-01-26 | 12 | -38/+34 | |
* | NEWLIB_RPMREL = 22%{?dist} | Ralf Corsepius | 2009-01-26 | 11 | -11/+11 | |
* | GCC_VERS = 1%{?dist} | Ralf Corsepius | 2009-01-26 | 11 | -11/+11 | |
* | GCC_VERS = 4.3.3 | Ralf Corsepius | 2009-01-26 | 11 | -11/+11 | |
* | BR: exact version of build host tools for Cdn-X builds. | Ralf Corsepius | 2009-01-26 | 45 | -236/+466 | |
* | Abandon gccnewlib_version. | Ralf Corsepius | 2009-01-26 | 1 | -1/+0 | |
* | Abandon suse10.2 | Ralf Corsepius | 2009-01-26 | 1 | -1/+0 | |
* | Abandon gcc < 3.2 | Ralf Corsepius | 2009-01-26 | 1 | -4/+0 | |
* | Add NEWLIB_RELEASE, %{newlib_release}. | Ralf Corsepius | 2009-01-26 | 4 | -6/+6 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-01-26 | 12 | -12/+24 | |
| | | | | Add NEWLIB_RPMREL. | |||||
* | New. | Ralf Corsepius | 2009-01-26 | 1 | -0/+253 | |
* | Remove. | Ralf Corsepius | 2009-01-22 | 10 | -6280/+0 | |
* | Add mingw hacks. | Ralf Corsepius | 2009-01-22 | 2 | -0/+18111 | |
* | Regenerate. | Ralf Corsepius | 2009-01-22 | 13 | -65/+364 | |
* | Update to gdb-*-20090122.diff | Ralf Corsepius | 2009-01-22 | 13 | -13/+13 | |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-01-22 | 13 | -13/+13 | |
* | Add hacks to work around Cdn-X and MinGW build issues. | Ralf Corsepius | 2009-01-22 | 2 | -1/+16 | |
* | Add i686-pc-mingw32-termcap-helper.spec.in. | Ralf Corsepius | 2009-01-22 | 2 | -0/+32 | |
* | New. | Ralf Corsepius | 2009-01-21 | 14 | -0/+436 | |
* | Add gmp, mpfr, *-helper. | Ralf Corsepius | 2009-01-21 | 1 | -2/+49 | |
* | Update. | Ralf Corsepius | 2009-01-21 | 1 | -1/+6 | |
* | Add freebsd7.1, freebsd6.4 | Ralf Corsepius | 2009-01-18 | 2 | -0/+4 | |
* | New. | Ralf Corsepius | 2009-01-18 | 22 | -0/+526 | |
* | Add more mingw32 hacks. | Ralf Corsepius | 2009-01-18 | 1 | -2/+10 | |
* | Add freebsd7.1 | Ralf Corsepius | 2009-01-17 | 2 | -1/+4 | |
* | newlib-1.17.0 | Ralf Corsepius | 2008-12-23 | 24 | -24/+24 | |
* | newlib-1.17.0 | Ralf Corsepius | 2008-12-23 | 70 | -171/+279 | |
* | Mingw32 update. | Ralf Corsepius | 2008-12-23 | 1 | -1/+1 | |
* | New. | Ralf Corsepius | 2008-12-23 | 1 | -0/+228 | |
* | Update to gcc-4.3.2 | Ralf Corsepius | 2008-12-22 | 1 | -1/+1 | |
