* | Don't install windmc.1 if windmc is not available. | Ralf Corsepius | 2008-07-27 | 1 | -0/+3 | |
* | Remove (Incorporated by upstream.) | Ralf Corsepius | 2008-07-07 | 1 | -11/+0 | |
* | New. | Ralf Corsepius | 2008-07-06 | 1 | -0/+11 | |
* | Add full URL to patch. | Ralf Corsepius | 2008-07-05 | 21 | -21/+21 | |
* | Add rtems-4.10. | Ralf Corsepius | 2008-07-03 | 1 | -0/+14 | |
* | gcc-core-4.3.1-rtems4.9-20080628.diff | Ralf Corsepius | 2008-07-03 | 2 | -2/+2 | |
* | New. | Ralf Corsepius | 2008-07-03 | 42 | -0/+12864 | |
* | Backup. | Ralf Corsepius | 2008-07-03 | 5 | -15/+47 | |
* | Add m68k/cf 5329 | Ralf Corsepius | 2008-07-03 | 1 | -0/+117 | |
* | Remove 4.3.0. | Ralf Corsepius | 2008-07-03 | 10 | -79/+9 | |
* | Set target to rtems4.10. | Ralf Corsepius | 2008-07-03 | 12 | -12/+12 | |
* | Reset *_RPMREL. | Ralf Corsepius | 2008-07-03 | 12 | -44/+44 | |
* | New. | Ralf Corsepius | 2008-07-03 | 76 | -0/+1183 | |
* | Upgrade to gcc-4.3.1 | Ralf Corsepius | 2008-06-09 | 1 | -7/+7 | |
* | Add gcc-4.3.1. Abandon gcc-4.2.3. | Ralf Corsepius | 2008-06-09 | 9 | -63/+68 | |
* | Upgrade to gcc-4.3.1. | Ralf Corsepius | 2008-06-09 | 10 | -20/+20 | |
* | Do not use string comparisions. | Ralf Corsepius | 2008-06-09 | 1 | -2/+2 | |
* | New. | Ralf Corsepius | 2008-06-09 | 1 | -0/+107 | |
* | Remove. | Ralf Corsepius | 2008-06-05 | 15 | -11331/+0 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-06-04 | 1 | -1/+1 | |
* | Upgrade to binutils-20080523-1. | Ralf Corsepius | 2008-06-04 | 2 | -3/+5 | |
* | Add hack to adjust n/ncr260vt300wpp | Ralf Corsepius | 2008-06-04 | 1 | -2/+4 | |
* | Bump ncurses RPMREL. | Ralf Corsepius | 2008-06-04 | 1 | -1/+1 | |
* | BR/R: terminfo | Ralf Corsepius | 2008-06-04 | 1 | -0/+3 | |
* | Add hack to adjust Eterm-color | Ralf Corsepius | 2008-06-04 | 1 | -1/+1 | |
* | Add hack to adjust Eterm-color | Ralf Corsepius | 2008-06-04 | 1 | -0/+4 | |
* | New. | Ralf Corsepius | 2008-06-04 | 3 | -0/+63 | |
* | Add TERMINFO. | Ralf Corsepius | 2008-06-04 | 1 | -0/+4 | |
* | Upgrade to cygwin-1.5.25-14 | Ralf Corsepius | 2008-06-04 | 1 | -2/+2 | |
* | Remove. | Ralf Corsepius | 2008-05-26 | 2 | -138/+0 | |
* | Remove. | Ralf Corsepius | 2008-05-26 | 2 | -101/+0 | |
* | New. | Ralf Corsepius | 2008-05-26 | 1 | -0/+44 | |
* | GCC 4.2.4 | Ralf Corsepius | 2008-05-26 | 2 | -2/+6 | |
* | Update. | Ralf Corsepius | 2008-05-10 | 1 | -53/+16 | |
* | New. | Ralf Corsepius | 2008-05-10 | 2 | -0/+44 | |
* | BuildRequire: m4 > 1.4.5 | Ralf Corsepius | 2008-05-09 | 1 | -0/+3 | |
* | Enable --with-system-readline only for gdb >= 6.7 | Ralf Corsepius | 2008-05-08 | 1 | -1/+3 | |
* | Regenerate. | Ralf Corsepius | 2008-05-01 | 22 | -144/+395 | |
* | Upgrade to newlib-1.16.0-rtems4.9-20080430.diff, ↵ | Ralf Corsepius | 2008-05-01 | 11 | -24/+20 | |
| | | | | gcc-core-4.3.0-rtems4.9-20080501.diff. | |||||
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-05-01 | 11 | -11/+11 | |
* | Add upstream SIZE_MIN/SIZE_MAX fixes. | Ralf Corsepius | 2008-05-01 | 1 | -0/+1817 | |
* | Add include-fixed to FLAGS_FOR_TARGET to let Cdn-X build succeed. | Ralf Corsepius | 2008-05-01 | 1 | -0/+107 | |
* | Improvements for gdb-6.6/6.7 | Ralf Corsepius | 2008-04-29 | 2 | -6/+2 | |
* | Once more rework erc32 simulator configuration. | Ralf Corsepius | 2008-04-29 | 1 | -0/+597 | |
* | Upgrade to gdb-6.8-rtems4.9-20080429.diff. | Ralf Corsepius | 2008-04-29 | 10 | -10/+10 | |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2008-04-29 | 11 | -11/+11 | |
* | Regenerate. | Ralf Corsepius | 2008-04-28 | 11 | -149/+337 | |
* | Remove. | Ralf Corsepius | 2008-04-28 | 4 | -6813/+0 | |
* | New. | Ralf Corsepius | 2008-04-28 | 1 | -0/+584 | |
* | Abandon gdb-6.7.1. | Ralf Corsepius | 2008-04-28 | 10 | -48/+11 | |
| | | | | Use gdb-6.8-rtems4.9-20080428.diff. |
