path: root/contrib/crossrpms (follow)
* Don't cvsignore rtems*.spec.Ralf Corsepius2009-09-131-1/+0
* Regenerate.Ralf Corsepius2009-09-1313-88/+88
* newlib-1.17.0-rtems4.10-20090911.diff.Ralf Corsepius2009-09-1312-12/+12
* Bump GCC_RPMREL for mass rebuild against binutils-2.19.90.Ralf Corsepius2009-09-1313-13/+13
* Regenerate.Ralf Corsepius2009-09-1313-82/+148
* Upgrade to binutils 2.19.90.Ralf Corsepius2009-09-1326-54/+54
* New.Ralf Corsepius2009-09-111-0/+1116
* Update.Ralf Corsepius2009-09-113-8/+8
* Regenerate.Ralf Corsepius2009-09-1113-89/+89
* newlib-1.17.0-rtems4.10-20090910.diffRalf Corsepius2009-09-1113-13/+13
* Bump GCC_RPMREL.Ralf Corsepius2009-09-1113-13/+13
* New.Ralf Corsepius2009-09-101-0/+1103
* Remove.Ralf Corsepius2009-09-094-3321/+0
* Regenerate.Ralf Corsepius2009-09-0913-89/+89
* newlib-1.17.0-rtems4.10-20090909.diff.Ralf Corsepius2009-09-0913-13/+13
* Bump GCC_RPMREL.Ralf Corsepius2009-09-0913-13/+13
* New.Ralf Corsepius2009-09-091-0/+1095
* Fix GDB_VERS.Ralf Corsepius2009-09-082-3/+3
* Update to gdb-6.8.50.20090908.Ralf Corsepius2009-09-086-14/+14
* gdb-6.8.50.20090908.Ralf Corsepius2009-09-086-14/+14
* Rebase against gdb-6.8.50.20090908.Ralf Corsepius2009-09-081-0/+544
* Regenerate.Ralf Corsepius2009-09-071-1/+1
* Regenerate.Ralf Corsepius2009-09-071-2/+1
* Bump GCC_RPMREL.Ralf Corsepius2009-09-071-1/+1
* Regenerate.Ralf Corsepius2009-09-071-20/+57
* Regenerate.Ralf Corsepius2009-09-0713-115/+89
* Bump GCC_RPMREL.Ralf Corsepius2009-09-0713-13/+13
* Don't push . into multilib subdirs.Ralf Corsepius2009-09-071-2/+1
* Remove %sysdir %{_prefix}Ralf Corsepius2009-09-071-1/+0
* Don't put _prefix into dirs.Ralf Corsepius2009-09-061-3/+0
* Regenerate.Ralf Corsepius2009-09-0613-102/+89
* Bump GCC_RPMREL.Ralf Corsepius2009-09-0613-13/+13
* newlib-1.17.0-rtems4.10-20090906.diffRalf Corsepius2009-09-0613-13/+13
* New.Ralf Corsepius2009-09-061-0/+1266
* Activate python.Ralf Corsepius2009-09-0514-13/+209
* Bump GDB_RPMREL = 2.Ralf Corsepius2009-09-0513-13/+13
* Fix %bcond_without/with python conditional.Ralf Corsepius2009-09-051-2/+2
* Add python support.Ralf Corsepius2009-09-052-0/+14
* Fix expat.Ralf Corsepius2009-09-033-6/+10
* Bump GDB_RPMREL.Ralf Corsepius2009-09-032-2/+2
* Regenerate.Ralf Corsepius2009-09-038-8/+8
* Reset GDB_RPMREL.Ralf Corsepius2009-09-038-8/+8
* Upgrade to gdb-6.8.50.20090902.Ralf Corsepius2009-09-0324-62/+88
* Upgrade to gdb-6.8.50.20090902.Ralf Corsepius2009-09-0215-78/+212
* New.Ralf Corsepius2009-09-021-0/+532
* Regenerate.Ralf Corsepius2009-09-0214-114/+100
* Bump GDB_RPMREL.Ralf Corsepius2009-09-0212-12/+12
* Bump GDB_RPMREL. Disable infos.Ralf Corsepius2009-09-022-4/+4
* Introduce noarch subpackages. Fix dir ownerships.Ralf Corsepius2009-09-022-0/+7
