* | newlib-1.15.0-rtems4.8-20071221.diff | Ralf Corsepius | 2007-12-21 | 3 | -5/+5 |
* | Regenerate. | Ralf Corsepius | 2007-12-17 | 2 | -3/+8 |
* | Sync. | Ralf Corsepius | 2007-12-17 | 1 | -3/+3 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2007-12-16 | 1 | -1/+1 |
* | gdb-6.6-rtems4.8-20071216.diff. | Ralf Corsepius | 2007-12-16 | 1 | -1/+1 |
* | Remove cpukit. | Ralf Corsepius | 2007-12-16 | 2 | -8/+0 |
* | Regnerate. | Ralf Corsepius | 2007-11-30 | 1 | -6/+6 |
* | GCC_RPMREL = 27. | Ralf Corsepius | 2007-11-30 | 1 | -1/+1 |
* | Upgrade to gcc-4.2.2 | Ralf Corsepius | 2007-11-29 | 2 | -4/+4 |
* | gcc-core-4.2.1-rtems4.8-20071129. | Ralf Corsepius | 2007-11-29 | 3 | -4/+4 |
* | backup. | Ralf Corsepius | 2007-11-13 | 1 | -21/+4 |
* | Remove gcc-3.4.6. | Ralf Corsepius | 2007-11-11 | 1 | -3/+0 |
* | Remove gcc-4.2.0. | Ralf Corsepius | 2007-11-11 | 1 | -4/+0 |
* | Remove gcc-4.0.3. | Ralf Corsepius | 2007-11-11 | 1 | -4/+0 |
* | Remove gcc-4.1.2. | Ralf Corsepius | 2007-11-11 | 1 | -4/+0 |
* | Remove gcc-4.1.1. | Ralf Corsepius | 2007-11-11 | 1 | -4/+0 |
* | gcc-core-4.2.1-rtems4.8-20071111.diff. | Ralf Corsepius | 2007-11-11 | 1 | -1/+1 |
* | GCC_RPMREL = 25. | Ralf Corsepius | 2007-11-11 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2007-11-04 | 1 | -6/+3 |
* | BINUTILS_RPMREL = 2. | Ralf Corsepius | 2007-11-04 | 1 | -1/+1 |
* | binutils-2.18-rtems4.8-20071104.diff. | Ralf Corsepius | 2007-11-04 | 1 | -5/+2 |
* | Upgrade to gdb-4.7.1 | Ralf Corsepius | 2007-11-01 | 3 | -48/+23 |
* | Update. | Ralf Corsepius | 2007-09-28 | 1 | -1/+0 |
* | Regenerate. | Ralf Corsepius | 2007-09-02 | 1 | -18/+4 |
* | BINUTILS_VERS = 2.18. | Ralf Corsepius | 2007-08-29 | 1 | -2/+2 |
| | | | | BINUTILS_RPMREL = 1%{?dist}. | ||||
* | New. | Ralf Corsepius | 2007-08-09 | 1 | -0/+226 |
* | Increment GDB_RPMREL. | Ralf Corsepius | 2007-08-09 | 1 | -1/+1 |
* | Append %{?dist} to GDB_RPMREL. | Ralf Corsepius | 2007-08-09 | 1 | -1/+1 |
* | GCC_RPMREL = 23. Rebuild against binutils-2.17.90. | Ralf Corsepius | 2007-08-08 | 3 | -26/+20 |
* | BINUTILS_RPMREL = 2 | Ralf Corsepius | 2007-08-07 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2007-08-07 | 1 | -4/+87 |
* | Enable infos for binutils. | Ralf Corsepius | 2007-08-07 | 1 | -2/+0 |
* | Upgrade to binutils-2.17.90. | Ralf Corsepius | 2007-08-07 | 2 | -3/+3 |
* | Regenerate. | Ralf Corsepius | 2007-08-07 | 1 | -0/+170 |
* | Update to newlib-1.15.0-rtems4.8-20070804.diff | Ralf Corsepius | 2007-08-04 | 1 | -1/+1 |
* | Move %{?dist} into BINUTILS_RPMREL. | Ralf Corsepius | 2007-07-24 | 1 | -1/+1 |
* | Move %{?dist} into GCC_RPMREL. | Ralf Corsepius | 2007-07-24 | 1 | -1/+1 |
* | Sync with testing. | Ralf Corsepius | 2007-07-20 | 1 | -1/+1 |
* | Sync with testing. | Ralf Corsepius | 2007-07-20 | 1 | -2/+2 |
* | Preps for gcc-4.2.1. | Ralf Corsepius | 2007-07-15 | 1 | -0/+4 |
* | Preps for next spin. | Ralf Corsepius | 2007-06-18 | 1 | -3/+7 |
* | GCC_RPMREL = 14 | Ralf Corsepius | 2007-06-18 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2007-06-18 | 1 | -2/+5 |
* | Regenerate. | Ralf Corsepius | 2007-06-13 | 1 | -2/+5 |
* | Add *20070613.diff | Ralf Corsepius | 2007-06-13 | 1 | -1/+4 |
* | GCC_RPMREL = 13 | Ralf Corsepius | 2007-06-13 | 1 | -1/+1 |
* | GCC_RPMREL = 12 | Ralf Corsepius | 2007-06-03 | 2 | -2/+2 |
* | New. | Ralf Corsepius | 2007-06-03 | 1 | -0/+546 |
* | Backup. | Ralf Corsepius | 2007-05-25 | 2 | -2/+7 |
* | New. | Ralf Corsepius | 2007-05-10 | 1 | -0/+2 |
