2010-06-07 | Remove. | Ralf Corsepius | 114 | -19658/+0 | |
2010-04-29 | Regenerate. | Ralf Corsepius | 13 | -166/+166 | |
2010-04-29 | GCC-4.4.4. | Ralf Corsepius | 26 | -78/+78 | |
2010-04-26 | Regenerate. | Ralf Corsepius | 13 | -95/+13 | |
2010-04-26 | Abandon gcc-4.4.2. | Ralf Corsepius | 13 | -104/+13 | |
newlib-1.18.0-rtems4.10-20100426.diff. | |||||
2010-04-26 | Regenerate. | Ralf Corsepius | 13 | -117/+234 | |
2010-04-26 | Bump GCC_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
2010-04-08 | Regenerate. | Ralf Corsepius | 13 | -104/+104 | |
2010-04-08 | Bump GCC_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
2010-04-08 | gcc-core-4.4.3-rtems4.10-20100315.diff. | Ralf Corsepius | 13 | -13/+13 | |
2010-04-06 | Regenerate. | Ralf Corsepius | 6 | -6/+18 | |
2010-04-06 | Bump GDB_RPMREL. | Ralf Corsepius | 6 | -6/+6 | |
2010-04-02 | Regenerate. | Ralf Corsepius | 13 | -104/+104 | |
2010-04-02 | Bump GCC_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
2010-04-02 | newlib-1.18.0-rtems4.10-20100402.diff | Ralf Corsepius | 13 | -13/+13 | |
2010-03-29 | Regenerate. | Ralf Corsepius | 27 | -1111/+2546 | |
2010-03-29 | Bump GDB_RPMREL. | Ralf Corsepius | 14 | -14/+14 | |
2010-03-29 | newlib-1.18.0-rtems4.10-20100328.diff | Ralf Corsepius | 13 | -13/+13 | |
2010-03-29 | Bump GCC_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
2010-03-26 | Abandon cpukit. | Ralf Corsepius | 13 | -79/+0 | |
2010-03-26 | Abandoned. | Ralf Corsepius | 2 | -36/+0 | |
2010-03-26 | Abandon. | Ralf Corsepius | 25 | -1922/+0 | |
2010-03-19 | Regenerate. | Ralf Corsepius | 13 | -78/+78 | |
2010-03-19 | gdb-7.1 | Ralf Corsepius | 13 | -26/+26 | |
2010-03-19 | gdb-7.1.spec | Ralf Corsepius | 13 | -39/+39 | |
2010-03-15 | Regenerate. | Ralf Corsepius | 13 | -104/+104 | |
2010-03-15 | GCC_RPMREL=6 | Ralf Corsepius | 13 | -13/+13 | |
2010-03-15 | newlib-1.18.0-rtems4.10-20100310.diff | Ralf Corsepius | 13 | -13/+13 | |
2010-03-10 | Regenerate. | Ralf Corsepius | 13 | -26/+26 | |
2010-03-10 | Add binutils-patch. | Ralf Corsepius | 13 | -13/+13 | |
2010-03-10 | Bump BINUTILS_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
2010-03-05 | Update to binutils-2.20.1 | Ralf Corsepius | 26 | -78/+78 | |
2010-02-25 | Regenerate. | Ralf Corsepius | 13 | -26/+26 | |
2010-02-25 | gdb-7.0.90-rtems4.10-20100225.diff. | Ralf Corsepius | 13 | -13/+13 | |
2010-02-25 | Bump GDG_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
2010-02-23 | gdb-7.0.90. | Ralf Corsepius | 39 | -39/+221 | |
2010-02-11 | Regenerate. | Ralf Corsepius | 13 | -101/+101 | |
2010-02-11 | GCC_RPMREL = 5. | Ralf Corsepius | 13 | -13/+13 | |
2010-02-10 | Remove cygwin hacks. | Ralf Corsepius | 26 | -78/+26 | |
2010-02-10 | Update. | Ralf Corsepius | 39 | -231/+231 | |
2010-01-21 | Upgrade to gcc-4.4.3. | Ralf Corsepius | 26 | -130/+286 | |
2010-01-21 | Regenerate. | Ralf Corsepius | 13 | -195/+225 | |
2010-01-21 | Update tp 4.4.3-RC-20100116. | Ralf Corsepius | 13 | -52/+52 | |
2010-01-21 | Update to newlib-1.18.0-rtems4.10-20100121.diff. | Ralf Corsepius | 13 | -13/+13 | |
2010-01-21 | Fix typo in previous patch. | Ralf Corsepius | 13 | -13/+13 | |
2010-01-21 | Preps for gcc-4.4.3. | Ralf Corsepius | 13 | -52/+91 | |
Abandon newlib-1.17.0. | |||||
2009-12-22 | gdb-7.0.1 | Ralf Corsepius | 39 | -65/+65 | |
2009-12-19 | Regenerate. | Ralf Corsepius | 13 | -131/+170 | |
2009-12-19 | Reset NEWLIB_RPMREL. | Ralf Corsepius | 13 | -26/+26 | |
NEWLIB_VERS = 1.18.0 | |||||
2009-12-19 | Bump GCC_RPMREL. | Ralf Corsepius | 13 | -13/+13 | |
