path: root/contrib/crossrpms/rtems4.10/m68k (follow)
* Regenerate.Ralf Corsepius2009-03-111-6/+6
* newlib-1.17.0-rtems4.10-20090311.diff.Ralf Corsepius2009-03-111-1/+1
* Bump GCC_RPMREL.Ralf Corsepius2009-03-111-1/+1
* Regenerate, fix spec file.Ralf Corsepius2009-02-241-2/+5
* Bump GDB_RPMREL.Ralf Corsepius2009-02-241-1/+1
* Regenerate.Ralf Corsepius2009-02-241-6/+6
* GCC_RPMREL = 8Ralf Corsepius2009-02-241-1/+1
* newlib-1.17.0-rtems4.10-20090224.diffRalf Corsepius2009-02-241-1/+1
* Regenerate.Ralf Corsepius2009-02-203-8/+8
* Regenerate.Ralf Corsepius2009-02-191-6/+6
* Move %{?dist} handling to rtems4.10/*.am.Ralf Corsepius2009-02-191-5/+5
* Update.Ralf Corsepius2009-02-191-1/+1
* Bump GCC_RPMREL, NEWLIB_RPMREL.Ralf Corsepius2009-02-191-2/+2
* Regenerate.Ralf Corsepius2009-02-072-7/+7
* Regenerate.Ralf Corsepius2009-02-061-2/+2
* Regenerate.Ralf Corsepius2009-02-061-13/+14
* newlib-1.17.0-rtems4.10-20090206.diffRalf Corsepius2009-02-061-1/+1
* Bump GCC_RPMREL, NEWLIB_RPMREL.Ralf Corsepius2009-02-061-4/+4
| | | | Rework CPUKIT*.
* Regenerate.Ralf Corsepius2009-02-031-5/+5
* Bump GCC_RPMREL, NEWLIB_RPMREL to rebuild against binutils-2.19.1Ralf Corsepius2009-02-031-2/+2
* Upgrade to binutils-2.19.1Ralf Corsepius2009-02-033-10/+10
* Regenerate.Ralf Corsepius2009-02-031-7/+6
* newlib-1.17.0-rtems4.10-20090203.diffRalf Corsepius2009-02-031-1/+1
* Bump GCC_RPMREL, NEWLIB_RPMREL.Ralf Corsepius2009-02-031-2/+2
* Regenerate.Ralf Corsepius2009-01-261-8/+10
* Bump GDB_RPMREL.Ralf Corsepius2009-01-261-1/+1
* Regenerate.Ralf Corsepius2009-01-261-8/+8
* Upgrade to gcc-4.3.3Ralf Corsepius2009-01-261-3/+3
* NEWLIB_RPMREL = 22%{?dist}Ralf Corsepius2009-01-261-1/+1
* GCC_VERS = 1%{?dist}Ralf Corsepius2009-01-261-1/+1
* GCC_VERS = 4.3.3Ralf Corsepius2009-01-261-1/+1
* BR: exact version of build host tools for Cdn-X builds.Ralf Corsepius2009-01-263-20/+38
* Bump GCC_RPMREL.Ralf Corsepius2009-01-261-1/+2
| | | | Add NEWLIB_RPMREL.
* Regenerate.Ralf Corsepius2009-01-221-5/+28
* Update to gdb-*-20090122.diffRalf Corsepius2009-01-221-1/+1
* Bump GDB_RPMREL.Ralf Corsepius2009-01-221-1/+1
* newlib-1.17.0Ralf Corsepius2008-12-232-2/+2
* newlib-1.17.0Ralf Corsepius2008-12-236-15/+27
* Regenerate.Ralf Corsepius2008-12-161-3/+3
* Update to newlib-1.16.0.cvs.20081216.Ralf Corsepius2008-12-162-3/+3
* Regenerate.Ralf Corsepius2008-12-121-3/+3
* newlib-1.16.0.cvs.20081212Ralf Corsepius2008-12-122-3/+3
* Regenerate.Ralf Corsepius2008-12-051-1/+1
* gcc-core-4.3.2-rtems4.10-20081205.diff.Ralf Corsepius2008-12-051-1/+1
* Regenerate.Ralf Corsepius2008-12-051-3/+3
* GCC_RPMREL = 17, newlib-1.16.0.cvs.20081205.Ralf Corsepius2008-12-052-3/+3
* Regenerate.Ralf Corsepius2008-11-281-3/+3
* newlib-1.16.0.cvs.20081128.Ralf Corsepius2008-11-282-3/+3
* Regenerate.Ralf Corsepius2008-11-271-3/+3
* newlib-1.16.0.cvs.20081127Ralf Corsepius2008-11-271-1/+1
