* | Disable m32c simulator. | Ralf Corsepius | 2009-03-10 | 1 | -0/+5 |
* | Disable lm32 simulator on mingw32. | Ralf Corsepius | 2009-02-25 | 1 | -0/+3 |
* | Use "%{?suse}" >= "10.3" to detect suse | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | Disable python. | Ralf Corsepius | 2009-02-24 | 1 | -0/+3 |
* | Abandon SuSE < 10.3 | Ralf Corsepius | 2009-01-26 | 1 | -6/+2 |
* | Add Cdn-X hacks. | Ralf Corsepius | 2009-01-26 | 1 | -1/+7 |
* | Add hacks to work around Cdn-X and MinGW build issues. | Ralf Corsepius | 2009-01-22 | 2 | -1/+16 |
* | Enable --with-system-readline only for gdb >= 6.7 | Ralf Corsepius | 2008-05-08 | 1 | -1/+3 |
* | Improvements for gdb-6.6/6.7 | Ralf Corsepius | 2008-04-29 | 2 | -6/+2 |
* | Minor restructurization. | Ralf Corsepius | 2008-04-28 | 1 | -7/+8 |
* | Use rtems_api. | Ralf Corsepius | 2008-04-26 | 1 | -1/+1 |
* | BR: %{_host_rpmprefix}readline-devel. | Ralf Corsepius | 2008-03-31 | 1 | -2/+8 |
| | | | | | BR: %{_host_rpmprefix}ncurses-devel. BR: %{_host_rpmprefix}termcap-devel for gdb < 6.6. | ||||
* | BR: %{_host_rpmprefix}expat-devel. | Ralf Corsepius | 2008-03-31 | 1 | -2/+3 |
* | Unconditionally BR: %{_host_rpmprefix}gcc. | Ralf Corsepius | 2008-03-31 | 1 | -3/+1 |
* | Remove readline/configure to force not building the bundled readline and use ↵ | Ralf Corsepius | 2008-03-31 | 1 | -0/+4 |
| | | | | the system provided readline. | ||||
* | Remove stray blank line. | Ralf Corsepius | 2008-03-26 | 1 | -1/+0 |
* | Add CFLAGS_FOR_BUILD. | Ralf Corsepius | 2008-03-26 | 1 | -0/+3 |
* | Add %{_host}-gcc for CdnX | Ralf Corsepius | 2008-03-24 | 1 | -0/+4 |
* | Add patch1. | Ralf Corsepius | 2008-03-24 | 1 | -0/+1 |
* | Add _bindir to $PATH. | Ralf Corsepius | 2008-03-24 | 2 | -0/+6 |
* | Add _smp_mflags. | Ralf Corsepius | 2007-12-16 | 1 | -1/+1 |
* | Assume gdb >= 6.4 | Ralf Corsepius | 2007-11-01 | 2 | -32/+0 |
* | Cleanups for erc32. | Ralf Corsepius | 2007-10-31 | 2 | -2/+3 |
* | Reflect suse-10.3 having expat in libexpat-devel. | Ralf Corsepius | 2007-10-31 | 1 | -1/+8 |
* | Force building against expat | Ralf Corsepius | 2007-10-31 | 1 | -0/+3 |
* | Cleanups. | Ralf Corsepius | 2007-09-28 | 1 | -1/+1 |
* | Remove references to base packages. | Ralf Corsepius | 2007-08-09 | 1 | -5/+0 |
* | Remove support for gdb < 6.0. | Ralf Corsepius | 2007-08-09 | 1 | -14/+0 |
* | Remove %{?dist} | Ralf Corsepius | 2007-08-09 | 1 | -1/+1 |
* | Sync with testing. | Ralf Corsepius | 2007-07-20 | 1 | -0/+4 |
* | BuildRequire: expat-devel for gdb >= 6.6 | Ralf Corsepius | 2007-02-17 | 1 | -0/+3 |
* | Add || : to install-info. | Ralf Corsepius | 2007-02-17 | 1 | -10/+10 |
* | Update sparc dep to rtems4.8 | Ralf Corsepius | 2006-10-30 | 1 | -1/+1 |
* | Let rpm Obsolete < %{gdb_version}-%{release} | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 |
* | Rename rtems4.7-base-gdb into gdb-common | Ralf Corsepius | 2006-07-22 | 3 | -11/+14 |
* | Require: base packages iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -0/+2 |
* | Cosmetics. | Ralf Corsepius | 2006-07-17 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2006-07-16 | 1 | -1/+4 |
* | Remove rpmlint warning on subject. | Ralf Corsepius | 2006-07-16 | 1 | -1/+1 |
* | Eliminate @osversion. Hard-code 4.7. | Ralf Corsepius | 2006-07-16 | 2 | -6/+6 |
* | BR: libtermcap-devel for sparc-rtems. | Ralf Corsepius | 2006-07-13 | 1 | -0/+4 |
* | Remove build_infos | Ralf Corsepius | 2006-07-05 | 1 | -2/+0 |
* | Replace %{build_infos} with %build_infos. | Ralf Corsepius | 2006-06-20 | 4 | -5/+5 |
* | Use %sysdir instead of %if %_prefix ==|!= /usr | Ralf Corsepius | 2006-03-17 | 2 | -8/+4 |
* | configure --enable-sim | Ralf Corsepius | 2006-03-11 | 1 | -0/+1 |
* | Use DESTDIR for gdb >= 6.3. | Ralf Corsepius | 2006-03-11 | 1 | -0/+9 |
| | | | | Remove bogus lib*-sim.a | ||||
* | Use %build_infos | Ralf Corsepius | 2006-03-10 | 4 | -11/+12 |
* | New. | Ralf Corsepius | 2006-03-10 | 7 | -0/+216 |
