* | Sync w/ cvs-head. | Ralf Corsepius | 2009-03-12 | 1 | -5/+30 |
* | Improvements for gdb-6.6/6.7 | Ralf Corsepius | 2008-04-29 | 1 | -4/+1 |
* | Minor restructurization. | Ralf Corsepius | 2008-04-28 | 1 | -7/+8 |
* | Use rtems_api. | Ralf Corsepius | 2008-04-26 | 1 | -1/+1 |
* | BR: %{_host_rpmprefix}readline-devel. | Ralf Corsepius | 2008-03-31 | 1 | -2/+8 |
| | | | | | BR: %{_host_rpmprefix}ncurses-devel. BR: %{_host_rpmprefix}termcap-devel for gdb < 6.6. | ||||
* | BR: %{_host_rpmprefix}expat-devel. | Ralf Corsepius | 2008-03-31 | 1 | -2/+3 |
* | Unconditionally BR: %{_host_rpmprefix}gcc. | Ralf Corsepius | 2008-03-31 | 1 | -3/+1 |
* | Add %{_host}-gcc for CdnX | Ralf Corsepius | 2008-03-24 | 1 | -0/+4 |
* | Cleanups for erc32. | Ralf Corsepius | 2007-10-31 | 1 | -2/+2 |
* | Reflect suse-10.3 having expat in libexpat-devel. | Ralf Corsepius | 2007-10-31 | 1 | -1/+8 |
* | Cleanups. | Ralf Corsepius | 2007-09-28 | 1 | -1/+1 |
* | Remove %{?dist} | Ralf Corsepius | 2007-08-09 | 1 | -1/+1 |
* | Sync with testing. | Ralf Corsepius | 2007-07-20 | 1 | -0/+4 |
* | BuildRequire: expat-devel for gdb >= 6.6 | Ralf Corsepius | 2007-02-17 | 1 | -0/+3 |
* | Update sparc dep to rtems4.8 | Ralf Corsepius | 2006-10-30 | 1 | -1/+1 |
* | Rename rtems4.7-base-gdb into gdb-common | Ralf Corsepius | 2006-07-22 | 1 | -2/+2 |
* | Cosmetics. | Ralf Corsepius | 2006-07-16 | 1 | -1/+4 |
* | BR: libtermcap-devel for sparc-rtems. | Ralf Corsepius | 2006-07-13 | 1 | -0/+4 |
* | Remove build_infos | Ralf Corsepius | 2006-07-05 | 1 | -2/+0 |
* | Replace %{build_infos} with %build_infos. | Ralf Corsepius | 2006-06-20 | 1 | -1/+1 |
* | Use %build_infos | Ralf Corsepius | 2006-03-10 | 1 | -3/+4 |
* | New. | Ralf Corsepius | 2006-03-10 | 1 | -0/+24 |
