* | Require base-gcc if build_infos is true. | Ralf Corsepius | 2006-07-16 | 2 | -2/+2 | |
* | Let *-gcc subpackage require base-package. | Ralf Corsepius | 2006-07-16 | 1 | -0/+3 | |
* | Eliminate @osversion. Hard-code 4.7. | Ralf Corsepius | 2006-07-16 | 11 | -39/+39 | |
* | Remove unused constructs. | Ralf Corsepius | 2006-07-05 | 1 | -73/+0 | |
* | GCC-4.1.1 still installs mf-runtime.h to the wrong directory. | Ralf Corsepius | 2006-06-21 | 1 | -1/+1 | |
* | Replace %{build_infos} with %build_infos. | Ralf Corsepius | 2006-06-20 | 8 | -8/+8 | |
* | Use %sysdir instead of %if %_prefix ==|!= /usr | Ralf Corsepius | 2006-03-17 | 8 | -23/+17 | |
* | Use %build_infos | Ralf Corsepius | 2006-03-10 | 9 | -9/+9 | |
* | Use gcc_rpmvers for subpackage deps. | Ralf Corsepius | 2006-03-07 | 6 | -6/+6 | |
* | Use %echo instead of %%echo in %expand | Ralf Corsepius | 2006-03-07 | 1 | -2/+2 | |
* | Renamed into *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -61/+0 | |
* | Renamed from *-libc.add to *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -0/+61 | |
* | gcc-4.1.0 still has issues with mudflap. | Ralf Corsepius | 2006-03-01 | 1 | -2/+2 | |
* | Revert to cd'ing into gcc-%{gcc_version} for gcc_update | Ralf Corsepius | 2006-02-27 | 1 | -2/+3 | |
* | Fix stupid typo. | Ralf Corsepius | 2006-02-25 | 1 | -1/+1 | |
* | Use gcc_rpmvers to setup Version: | Ralf Corsepius | 2006-02-25 | 10 | -10/+10 | |
* | Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around rpmbuild ↵ | Ralf Corsepius | 2006-02-24 | 1 | -6/+6 | |
| | | | | screwing up on %version. | |||||
* | Invoke gcc-%{gcc_version}/configure | Ralf Corsepius | 2006-02-24 | 1 | -1/+1 | |
* | Add @PREP@, remove RTEMS version magic | Ralf Corsepius | 2006-02-24 | 1 | -12/+2 | |
* | Allow shared libgfortran | Ralf Corsepius | 2006-02-24 | 1 | -1/+1 | |
* | Use gcc_version instead of %version, to work around rpm screwing up on ↵ | Ralf Corsepius | 2006-02-22 | 1 | -6/+6 | |
| | | | | %version in mixed-versioned packages. | |||||
* | Run make install-info to get the newlib infos | Ralf Corsepius | 2006-02-22 | 1 | -0/+6 | |
* | Cleanup comment on vxaddr2line. | Ralf Corsepius | 2006-02-22 | 1 | -1/+1 | |
* | Add ",g" in sed call to propagate _prefix to brp-compress. | Ralf Corsepius | 2006-02-22 | 1 | -1/+1 | |
* | Correct /-handling | Ralf Corsepius | 2006-02-22 | 1 | -1/+1 | |
* | Rename libc to newlib. | Ralf Corsepius | 2006-02-21 | 3 | -9/+10 | |
* | Rename files.libc to files.newlib. | Ralf Corsepius | 2006-02-21 | 2 | -9/+9 | |
* | Require/BuildRequire: w32api-sys-root, Remove a comment. | Ralf Corsepius | 2006-02-20 | 1 | -1/+3 | |
* | Add blank line. | Ralf Corsepius | 2006-02-20 | 1 | -0/+1 | |
* | Comment out @tool_target@-gcc %package | Ralf Corsepius | 2006-02-18 | 1 | -7/+7 | |
* | Add NEWLIB_VERS | Ralf Corsepius | 2006-02-18 | 1 | -1/+1 | |
* | Reflect newlib having been split out | Ralf Corsepius | 2006-02-18 | 1 | -13/+1 | |
* | Add @rpmprefix@ in comments. | Ralf Corsepius | 2006-02-18 | 7 | -7/+7 | |
* | Remove hard-coded default for _cxx for mingw | Ralf Corsepius | 2006-02-18 | 1 | -4/+0 | |
* | Remove %prep, %build | Ralf Corsepius | 2006-02-18 | 1 | -119/+0 | |
* | New. | Ralf Corsepius | 2006-02-18 | 2 | -0/+119 | |
* | Cosmetics. | Ralf Corsepius | 2006-02-17 | 3 | -5/+3 | |
* | Cosmetics | Ralf Corsepius | 2006-02-17 | 1 | -1/+1 | |
* | Add %build_newlib guard | Ralf Corsepius | 2006-02-17 | 1 | -3/+3 | |
* | New. | Ralf Corsepius | 2006-02-17 | 1 | -0/+38 | |
* | Install newlib infos only if building newlib | Ralf Corsepius | 2006-02-17 | 1 | -4/+4 | |
* | Eliminate %gcc_target | Ralf Corsepius | 2006-02-16 | 1 | -2/+0 | |
* | Eliminate %{rpmgroup} | Ralf Corsepius | 2006-02-16 | 14 | -14/+14 | |
* | Add %{?dist} to Release. | Ralf Corsepius | 2006-02-16 | 1 | -1/+4 | |
* | (libc.info,libm.info): Only install for newlib. | Ralf Corsepius | 2006-02-16 | 1 | -2/+6 | |
* | Abandon gcc < 3.0 | Ralf Corsepius | 2006-02-16 | 1 | -15/+0 | |
* | New (From rtems/scripts) | Ralf Corsepius | 2006-02-15 | 16 | -0/+990 | |
