* | Apply %{?_smp_mflags}. | Ralf Corsepius | 2007-12-21 | 1 | -1/+1 |
* | Backport from HEAD. | Ralf Corsepius | 2007-11-13 | 1 | -0/+2 |
* | Move %{?dist} into GCC_RPMREL. | Ralf Corsepius | 2007-07-24 | 1 | -1/+1 |
* | Various patches from rtems-4-8-testing branch. | Ralf Corsepius | 2007-07-22 | 7 | -38/+2 |
* | --disable-libstdcxx-pch | Ralf Corsepius | 2007-06-18 | 1 | -0/+1 |
* | Remove %{_libdir}/libiberty.a | Ralf Corsepius | 2007-05-24 | 1 | -1/+1 |
* | Add --libexecdir. | Ralf Corsepius | 2007-05-21 | 1 | -0/+1 |
* | Add exec_prefix. | Ralf Corsepius | 2007-03-06 | 4 | -8/+9 |
* | mf-runtime.h is still broken in gcc-4.1.2 | Ralf Corsepius | 2007-02-27 | 1 | -1/+1 |
* | Fix typo. | Ralf Corsepius | 2007-02-17 | 1 | -1/+1 |
* | Ignore errors on install-info. | Ralf Corsepius | 2007-02-16 | 6 | -28/+28 |
* | 'BR: flex bison' for gcc >= 4.2.0 | Ralf Corsepius | 2006-11-10 | 1 | -0/+3 |
* | Introduce GCC_PKGVERS | Ralf Corsepius | 2006-11-09 | 3 | -5/+5 |
* | 2006-08-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-08-23 | 1 | -6/+0 |
| | | | | * gcc/build.add: Revert --disable-libssp etc. hacks. | ||||
* | 2006-08-11 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-08-11 | 2 | -0/+8 |
| | | | | | | | | | | | | | * configure.ac, gcc/build.add, gcc/target-gcc.add: Add bfin target prior to merge. Add ability to disable libssp and libstdcxx-pch which apparently are required to build the Blackfin port. * patches/binutils-2.17-rtems-bfin-20060810.diff, patches/gcc-4.1.1-bfinrtems-20060810a.diff, patches/gdb-6.5-bfinrtems-20060810a.diff, patches/newlib-1.14.0-bfinrtems-20060810a.diff, rtems4.7/bfin/.cvsignore, rtems4.7/bfin/Makefile.am, rtems4.7/bfin/binutils-sources.add, rtems4.7/bfin/gcc-sources.add, rtems4.7/bfin/gdb-sources.add: New files. | ||||
* | More %if %build_newlib blocks. | Ralf Corsepius | 2006-07-25 | 2 | -0/+4 |
* | Minor fixes. | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 |
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 2 | -4/+8 |
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -9/+10 |
| | | | | Rename *gfortran into *gcc-gfortran | ||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -8/+9 |
| | | | | Rename *g77 into *gcc-g77 | ||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -4/+7 |
| | | | | Rename *objc into *gcc-objc | ||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -1/+2 |
| | | | | Rename *gcj into *gcc-gcj | ||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -4/+5 |
| | | | | Rename *gnat into *gcc-gnat | ||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -5/+8 |
| | | | | Rename *c++ into *gcc-c++ | ||||
* | Rename *base packages into gcc*-common | Ralf Corsepius | 2006-07-23 | 6 | -35/+69 |
* | Add --enable-threads. | Ralf Corsepius | 2006-07-23 | 1 | -0/+1 |
* | Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp | Ralf Corsepius | 2006-07-21 | 1 | -0/+3 |
* | Remove infos and man7 if !%build_infos. | Ralf Corsepius | 2006-07-18 | 1 | -3/+1 |
* | Require: base packages iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -0/+4 |
* | Require: base-g77 iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -0/+2 |
* | Require: base-gfortran iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2006-07-17 | 3 | -3/+3 |
* | Require base-gnat if build_infos is true. | Ralf Corsepius | 2006-07-16 | 1 | -1/+1 |
* | Require base-gcc if build_infos is true. | Ralf Corsepius | 2006-07-16 | 2 | -2/+2 |
* | Let *-gcc subpackage require base-package. | Ralf Corsepius | 2006-07-16 | 1 | -0/+3 |
* | Eliminate @osversion. Hard-code 4.7. | Ralf Corsepius | 2006-07-16 | 11 | -39/+39 |
* | Remove unused constructs. | Ralf Corsepius | 2006-07-05 | 1 | -73/+0 |
* | GCC-4.1.1 still installs mf-runtime.h to the wrong directory. | Ralf Corsepius | 2006-06-21 | 1 | -1/+1 |
* | Replace %{build_infos} with %build_infos. | Ralf Corsepius | 2006-06-20 | 8 | -8/+8 |
* | Use %sysdir instead of %if %_prefix ==|!= /usr | Ralf Corsepius | 2006-03-17 | 8 | -23/+17 |
* | Use %build_infos | Ralf Corsepius | 2006-03-10 | 9 | -9/+9 |
* | Use gcc_rpmvers for subpackage deps. | Ralf Corsepius | 2006-03-07 | 6 | -6/+6 |
* | Use %echo instead of %%echo in %expand | Ralf Corsepius | 2006-03-07 | 1 | -2/+2 |
* | Renamed into *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -61/+0 |
* | Renamed from *-libc.add to *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -0/+61 |
* | gcc-4.1.0 still has issues with mudflap. | Ralf Corsepius | 2006-03-01 | 1 | -2/+2 |
* | Revert to cd'ing into gcc-%{gcc_version} for gcc_update | Ralf Corsepius | 2006-02-27 | 1 | -2/+3 |
* | Fix stupid typo. | Ralf Corsepius | 2006-02-25 | 1 | -1/+1 |
* | Use gcc_rpmvers to setup Version: | Ralf Corsepius | 2006-02-25 | 10 | -10/+10 |
* | Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around rpmbuild ↵ | Ralf Corsepius | 2006-02-24 | 1 | -6/+6 |
| | | | | screwing up on %version. |
