path: root/contrib/crossrpms/gcc/target-newlib.add (follow)
* This commit was manufactured by cvs2svn to create tag 'rtems-4-7-0'.4.7.0cvs2git2007-03-051-27/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Sprout from rtems-4-7-branch 2007-03-05 20:53:27 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2007-03-05 Joel Sherrill <joel@OARcorp.com>' Delete: Makefile.maint contrib/apt-conf/.cvsignore contrib/apt-conf/COPYING contrib/apt-conf/ChangeLog contrib/apt-conf/INSTALL contrib/apt-conf/Makefile.am contrib/apt-conf/README contrib/apt-conf/configure.ac contrib/apt-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458 contrib/apt-conf/rtems-apt-conf.spec.in contrib/apt-conf/sources.list.d/rtems-4.6.list contrib/apt-conf/sources.list.d/rtems-4.7.list contrib/apt-conf/vendors.list.d/rtems.list contrib/crossrpms/.cvsignore contrib/crossrpms/AUTHORS contrib/crossrpms/COPYING contrib/crossrpms/ChangeLog contrib/crossrpms/Makefile.am contrib/crossrpms/NEWS contrib/crossrpms/README contrib/crossrpms/TODO contrib/crossrpms/acinclude.m4 contrib/crossrpms/autotools/.cvsignore contrib/crossrpms/autotools/Makefile.am contrib/crossrpms/autotools/autoconf.add contrib/crossrpms/autotools/autoconf.am contrib/crossrpms/autotools/automake.add contrib/crossrpms/autotools/automake.am contrib/crossrpms/autotools/target-autoconf.add contrib/crossrpms/autotools/target-automake.add contrib/crossrpms/binutils/.cvsignore contrib/crossrpms/binutils/base-binutils.add contrib/crossrpms/binutils/binutils.add contrib/crossrpms/binutils/build.add contrib/crossrpms/binutils/install.add contrib/crossrpms/binutils/prep.add contrib/crossrpms/binutils/rpm-install.add contrib/crossrpms/binutils/target-binutils.add contrib/crossrpms/bootstrap contrib/crossrpms/common/clean.add contrib/crossrpms/common/common.add contrib/crossrpms/configure.ac contrib/crossrpms/gcc/base-g77.add contrib/crossrpms/gcc/base-gcc.add contrib/crossrpms/gcc/base-gcj.add contrib/crossrpms/gcc/base-gfortran.add contrib/crossrpms/gcc/base-gnat.add contrib/crossrpms/gcc/base-newlib.add contrib/crossrpms/gcc/build.add contrib/crossrpms/gcc/gccnewlib.add contrib/crossrpms/gcc/install.add contrib/crossrpms/gcc/prep.add contrib/crossrpms/gcc/rpm-install.add contrib/crossrpms/gcc/target-c++.add contrib/crossrpms/gcc/target-g77.add contrib/crossrpms/gcc/target-gcc.add contrib/crossrpms/gcc/target-gcj.add contrib/crossrpms/gcc/target-gfortran.add contrib/crossrpms/gcc/target-gnat.add contrib/crossrpms/gcc/target-newlib.add contrib/crossrpms/gcc/target-objc.add contrib/crossrpms/gdb/base-gdb.add contrib/crossrpms/gdb/build.add contrib/crossrpms/gdb/gdb.add contrib/crossrpms/gdb/install.add contrib/crossrpms/gdb/prep.add contrib/crossrpms/gdb/rpm-install.add contrib/crossrpms/gdb/target-gdb.add contrib/crossrpms/mkspec.am contrib/crossrpms/patches/binutils-2.16.1-rtems-20050708.diff contrib/crossrpms/patches/binutils-2.17-rtems4.7-20061021.diff contrib/crossrpms/patches/gcc-core-4.0.3-rtems-20060822.diff contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.7-20070102.diff contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.7-20070216.diff contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff contrib/crossrpms/patches/gdb-6.6-rtems4.7-20070218.diff contrib/crossrpms/patches/gdb-6.6-rtems4.7-20070222.diff contrib/crossrpms/patches/newlib-1.14.0-rtems4.7-20061019.diff contrib/crossrpms/patches/newlib-1.15.0-rtems4.7-20070208.diff contrib/crossrpms/rtems4.7/.cvsignore contrib/crossrpms/rtems4.7/Makefile.am contrib/crossrpms/rtems4.7/arm/.cvsignore contrib/crossrpms/rtems4.7/arm/Makefile.am contrib/crossrpms/rtems4.7/arm/binutils-sources.add contrib/crossrpms/rtems4.7/arm/gcc-sources.add contrib/crossrpms/rtems4.7/arm/gdb-sources.add contrib/crossrpms/rtems4.7/avr/.cvsignore contrib/crossrpms/rtems4.7/avr/Makefile.am contrib/crossrpms/rtems4.7/avr/binutils-sources.add contrib/crossrpms/rtems4.7/avr/gcc-sources.add contrib/crossrpms/rtems4.7/avr/gdb-sources.add contrib/crossrpms/rtems4.7/binutils.am contrib/crossrpms/rtems4.7/gcc-prep.add contrib/crossrpms/rtems4.7/gcc.am contrib/crossrpms/rtems4.7/gdb.am contrib/crossrpms/rtems4.7/h8300/.cvsignore contrib/crossrpms/rtems4.7/h8300/Makefile.am contrib/crossrpms/rtems4.7/h8300/binutils-sources.add contrib/crossrpms/rtems4.7/h8300/gcc-sources.add contrib/crossrpms/rtems4.7/h8300/gdb-sources.add contrib/crossrpms/rtems4.7/i386/.cvsignore contrib/crossrpms/rtems4.7/i386/Makefile.am contrib/crossrpms/rtems4.7/i386/binutils-sources.add contrib/crossrpms/rtems4.7/i386/gcc-sources.add contrib/crossrpms/rtems4.7/i386/gdb-sources.add contrib/crossrpms/rtems4.7/m68k/.cvsignore contrib/crossrpms/rtems4.7/m68k/Makefile.am contrib/crossrpms/rtems4.7/m68k/binutils-sources.add contrib/crossrpms/rtems4.7/m68k/gcc-sources.add contrib/crossrpms/rtems4.7/m68k/gdb-sources.add contrib/crossrpms/rtems4.7/mips/.cvsignore contrib/crossrpms/rtems4.7/mips/Makefile.am contrib/crossrpms/rtems4.7/mips/binutils-sources.add contrib/crossrpms/rtems4.7/mips/gcc-sources.add contrib/crossrpms/rtems4.7/mips/gdb-sources.add contrib/crossrpms/rtems4.7/mipstx39/.cvsignore contrib/crossrpms/rtems4.7/mipstx39/Makefile.am contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add contrib/crossrpms/rtems4.7/powerpc/.cvsignore contrib/crossrpms/rtems4.7/powerpc/Makefile.am contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add contrib/crossrpms/rtems4.7/sh/.cvsignore contrib/crossrpms/rtems4.7/sh/Makefile.am contrib/crossrpms/rtems4.7/sh/binutils-sources.add contrib/crossrpms/rtems4.7/sh/gcc-sources.add contrib/crossrpms/rtems4.7/sh/gdb-sources.add contrib/crossrpms/rtems4.7/sparc/.cvsignore contrib/crossrpms/rtems4.7/sparc/Makefile.am contrib/crossrpms/rtems4.7/sparc/binutils-sources.add contrib/crossrpms/rtems4.7/sparc/gcc-sources.add contrib/crossrpms/rtems4.7/sparc/gdb-sources.add contrib/crossrpms/specstrip contrib/mingw/.cvsignore contrib/mingw/AUTHORS contrib/mingw/COPYING contrib/mingw/ChangeLog contrib/mingw/README contrib/mingw/build-exes.sh contrib/mingw/build-rpms.sh contrib/mingw/build.sh contrib/mingw/rtems-license.rtf contrib/mingw/rtems-tools.nsi contrib/mingw/rtems.ini contrib/mingw/rtems_logo.bmp contrib/mingw/targets contrib/repo-conf/.cvsignore contrib/repo-conf/AUTHORS contrib/repo-conf/COPYING contrib/repo-conf/ChangeLog contrib/repo-conf/INSTALL contrib/repo-conf/Makefile.am contrib/repo-conf/NEWS contrib/repo-conf/README contrib/repo-conf/aclocal/version.m4 contrib/repo-conf/apt/sources.list.d/.cvsignore contrib/repo-conf/apt/sources.list.d/rtems.list.in contrib/repo-conf/apt/vendors.list.d/rtems.list contrib/repo-conf/configure.ac contrib/repo-conf/gpg/gpg-pubkey-69ce4a83-44cc2b30 contrib/repo-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458 contrib/repo-conf/rtems-repo-conf.spec.in contrib/repo-conf/yum.repos.d/.cvsignore contrib/repo-conf/yum.repos.d/rtems.repo.in contrib/rtemsrpms/.cvsignore contrib/rtemsrpms/AUTHORS contrib/rtemsrpms/COPYING contrib/rtemsrpms/ChangeLog contrib/rtemsrpms/INSTALL contrib/rtemsrpms/Makefile.am contrib/rtemsrpms/NEWS contrib/rtemsrpms/README contrib/rtemsrpms/bootstrap contrib/rtemsrpms/configure.ac contrib/rtemsrpms/rtems.spec.in testsuites/samples/base_sp/.cvsignore
* Rename *base packages into gcc*-common gcc/base*.addRalf Corsepius2006-07-231-1/+7
* Use %sysdir instead of %if %_prefix ==|!= /usrRalf Corsepius2006-03-171-3/+1
* Renamed from *-libc.add to *-newlib.addRalf Corsepius2006-03-071-0/+23
