* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -8/+9 |
| | | | | Rename *g77 into *gcc-g77 | ||||
* | Require: base-g77 iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -0/+2 |
* | Eliminate @osversion. Hard-code 4.7. | Ralf Corsepius | 2006-07-16 | 1 | -1/+1 |
* | Use gcc_rpmvers for subpackage deps. | Ralf Corsepius | 2006-03-07 | 1 | -1/+1 |
* | Use gcc_rpmvers to setup Version: | Ralf Corsepius | 2006-02-25 | 1 | -1/+1 |
* | Add @rpmprefix@ in comments. | Ralf Corsepius | 2006-02-18 | 1 | -1/+1 |
* | Eliminate %{rpmgroup} | Ralf Corsepius | 2006-02-16 | 1 | -1/+1 |
* | New (From rtems/scripts) | Ralf Corsepius | 2006-02-15 | 1 | -0/+29 |
