* | Add lm32. | Ralf Corsepius | 2009-02-22 | 1 | -1/+2 |
* | BR: exact version of build host tools for Cdn-X builds. | Ralf Corsepius | 2009-01-26 | 1 | -1/+1 |
* | Add freebsd7.1, freebsd6.4 | Ralf Corsepius | 2009-01-18 | 1 | -0/+3 |
* | Add freebsd7.1 | Ralf Corsepius | 2009-01-17 | 1 | -1/+3 |
* | Bump version. | Ralf Corsepius | 2008-11-05 | 1 | -1/+1 |
* | Add m32r, m32c. | Ralf Corsepius | 2008-10-03 | 1 | -0/+2 |
* | Bump RTEMS_API to 4.10. | Ralf Corsepius | 2008-09-10 | 1 | -1/+1 |
* | Remove freebsd6.2, freebsd6.3, rtems4.9. | Ralf Corsepius | 2008-09-10 | 1 | -19/+0 |
* | Remove tic4x (Abandoned). | Ralf Corsepius | 2008-08-27 | 1 | -1/+0 |
* | Abandon rtems4.10/tic4x. | Ralf Corsepius | 2008-08-27 | 1 | -1/+0 |
* | Add rtems-4.10. | Ralf Corsepius | 2008-07-03 | 1 | -0/+14 |
* | Add rtems_api. | Ralf Corsepius | 2008-04-26 | 1 | -0/+1 |
* | Bump version. | Ralf Corsepius | 2008-03-06 | 1 | -1/+1 |
* | Abandon freebsd6.1. | Ralf Corsepius | 2008-03-05 | 1 | -3/+0 |
* | Add freebsd6.3, freebsd7.0 | Ralf Corsepius | 2008-03-05 | 1 | -1/+7 |
* | Abandon freebsd6.0 | Ralf Corsepius | 2008-03-05 | 1 | -3/+0 |
* | Abandon freebsd5.2 | Ralf Corsepius | 2008-03-05 | 1 | -3/+0 |
* | Require autoconf-2.61. | Ralf Corsepius | 2008-02-27 | 1 | -2/+2 |
| | | | | Bump version. | ||||
* | rtems-4.9. | Ralf Corsepius | 2007-09-28 | 1 | -14/+14 |
* | Add freebsd6.2 | Ralf Corsepius | 2007-02-27 | 1 | -2/+5 |
* | Add HOST_SUBDIRS | Ralf Corsepius | 2007-02-16 | 1 | -0/+6 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -1/+1 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | Remove rtems-4.7 | Ralf Corsepius | 2006-10-27 | 1 | -13/+0 |
* | Add rtems-4.8 | Ralf Corsepius | 2006-10-22 | 1 | -1/+14 |
* | 2006-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-16 | 1 | -2/+2 |
| | | | | * configure.ac: Set RTEMS_API to 4.8. | ||||
* | 2006-08-11 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-08-11 | 1 | -0/+1 |
| | | | | | | | | | | | | | * configure.ac, gcc/build.add, gcc/target-gcc.add: Add bfin target prior to merge. Add ability to disable libssp and libstdcxx-pch which apparently are required to build the Blackfin port. * patches/binutils-2.17-rtems-bfin-20060810.diff, patches/gcc-4.1.1-bfinrtems-20060810a.diff, patches/gdb-6.5-bfinrtems-20060810a.diff, patches/newlib-1.14.0-bfinrtems-20060810a.diff, rtems4.7/bfin/.cvsignore, rtems4.7/bfin/Makefile.am, rtems4.7/bfin/binutils-sources.add, rtems4.7/bfin/gcc-sources.add, rtems4.7/bfin/gdb-sources.add: New files. | ||||
* | Bump version. | Ralf Corsepius | 2006-08-03 | 1 | -1/+1 |
* | Bump version. | Ralf Corsepius | 2006-08-02 | 1 | -1/+1 |
* | Bump version. | Ralf Corsepius | 2006-07-24 | 1 | -1/+3 |
| | | | | Add AC_CONFIG_FILES([autotools/Makefile]) | ||||
* | Bump version | Ralf Corsepius | 2006-07-23 | 1 | -1/+1 |
* | Remove $build_infos. | Ralf Corsepius | 2006-07-20 | 1 | -9/+6 |
| | | | | Add SPECSTRIP_OPTS. | ||||
* | Fix setting up targets for solaris* | Ralf Corsepius | 2006-07-18 | 1 | -2/+7 |
* | Use <os>/<arch>/Makefile.am in check for all/rtems. | Ralf Corsepius | 2006-07-14 | 1 | -8/+12 |
* | 2006-07-13 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-07-13 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | * configure.ac, rtems4.7/Makefile.am, rtems4.7/arm/Makefile.am, rtems4.7/arm/gdb-sources.add, rtems4.7/avr/Makefile.am, rtems4.7/avr/gdb-sources.add, rtems4.7/h8300/Makefile.am, rtems4.7/h8300/gdb-sources.add, rtems4.7/i386/Makefile.am, rtems4.7/i386/gdb-sources.add, rtems4.7/m68k/Makefile.am, rtems4.7/m68k/gdb-sources.add, rtems4.7/mips/Makefile.am, rtems4.7/mips/gdb-sources.add, rtems4.7/powerpc/Makefile.am, rtems4.7/powerpc/gdb-sources.add, rtems4.7/sh/Makefile.am, rtems4.7/sh/gdb-sources.add, rtems4.7/sparc/Makefile.am, rtems4.7/sparc/gdb-sources.add, rtems4.7/tic4x/gdb-sources.add: Updated to gdb 6.5 * patches/gdb-6.5-rtems-20060713.diff, rtems4.7/mipstx39/.cvsignore, rtems4.7/mipstx39/Makefile.am, rtems4.7/mipstx39/gdb-sources.add: New files. | ||||
* | Bump version. | Ralf Corsepius | 2006-07-07 | 1 | -1/+1 |
* | Bump version. | Ralf Corsepius | 2006-07-05 | 1 | -1/+1 |
* | Eliminate target_os | Ralf Corsepius | 2006-07-05 | 1 | -19/+0 |
* | Remove AC_CANONICAL_TARGET. | Ralf Corsepius | 2006-07-05 | 1 | -1/+0 |
* | Add --enable-targets. | Ralf Corsepius | 2006-07-05 | 1 | -0/+48 |
* | Add new AC_CONFIG_FILES. | Ralf Corsepius | 2006-07-05 | 1 | -1/+23 |
* | Fix typo in previous change | Ralf Corsepius | 2006-06-25 | 1 | -1/+1 |
* | Bump version | Ralf Corsepius | 2006-06-25 | 1 | -1/+1 |
* | Add freebsd6.1 | Ralf Corsepius | 2006-06-20 | 1 | -1/+2 |
* | Bump version. | Ralf Corsepius | 2006-06-17 | 1 | -1/+2 |
| | | | | Add freebsd6.1 | ||||
* | Add defaults for non-standard $prefix. | Ralf Corsepius | 2006-03-23 | 1 | -2/+7 |
* | Apply @sysdirpattern@ | Ralf Corsepius | 2006-03-17 | 1 | -1/+6 |
* | Remove message erroniously checked in in previous change | Ralf Corsepius | 2006-03-16 | 1 | -1/+0 |
* | Set defaults for ac_default_prefix | Ralf Corsepius | 2006-03-16 | 1 | -1/+2 |
* | Increment version | Ralf Corsepius | 2006-03-15 | 1 | -1/+1 |
* | Increment version | Ralf Corsepius | 2006-03-10 | 1 | -1/+1 |
