* rtems4.10/sparc/Makefile.am: Bump RTEMS CPU Kit version.
* patches/gcc-ada-4.3.2-rtems4.10-20080910.diff: New file.
* patches/gcc-ada-4.2.0-rtems4.8-20070705.diff: Removed.
* rtems4.8/.cvsignore, rtems4.8/arm/.cvsignore,
rtems4.8/avr/.cvsignore, rtems4.8/bfin/.cvsignore,
rtems4.8/h8300/.cvsignore, rtems4.8/i386/.cvsignore,
rtems4.8/m68k/.cvsignore, rtems4.8/mips/.cvsignore,
rtems4.8/mipstx39/.cvsignore, rtems4.8/powerpc/.cvsignore,
rtems4.8/sh/.cvsignore, rtems4.8/sparc/.cvsignore,
rtems4.8/tic4x/.cvsignore: New.
* autotools/Makefile.am, autotools/autoconf.add:
Upgrade to autoconf-2.61.
* patches/gcc-core-4.2-20061114-rtems4.8-20061115.diff: New.
* patches/newlib-1.14.0-bfinrtems-20060810a.diff: Remove (Obsolete).
* patches/gcc-4.1.1-bfinrtems-20060810a.diff: Remove (Obsolete).
* rtems-4.8/bfin/Makefile.am, rtems-4.8/bin/gcc-sources.add:
GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff.
* configure.ac, Makefile.am: Remove rtems4.7.
* rtems4.7: Remove (Development now in rtems-4-7-branch only).
* patches/newlib-1.14.0-rtems4.8-20061027.diff: New.
* patches/newlib-1.14.0-rtems-20061026.diff: Remove (broken).
* patches/newlib-1.14.0-rtems-20061026.diff: New file.
* Makefile.am, configure.ac: Add rtems-4.8.
* configure.ac: Set RTEMS_API to 4.8.
* autotools/Makefile.am, autotools/automake.add: Update to
automake-1.10.
* rtems4.7/arm/gcc-sources.add, rtems4.7/h8300/gcc-sources.add,
rtems4.7/i386/gcc-sources.add, rtems4.7/m68k/gcc-sources.add,
rtems4.7/mips/gcc-sources.add, rtems4.7/powerpc/gcc-sources.add
rtems4.7/sh/gcc-sources.add, rtems4.7/sparc/gcc-sources.add
rtems4.7/tic4x/gcc-sources.add: Add gcc-4.0.3.
* gcc/build.add: Revert --disable-libssp etc. hacks.
* rtems4.7/avr/gcc-sources.add: Add the 4.0.3 patch.
* patches/gcc-core-4.0.3-rtems-20060822.diff:
The .exe for the versioned execuable for MinGW.
* rtems4.7/h8300/binutils-sources.add,
rtems4.7/m68k/binutils-sources.add: Add h8300 _tinydata patch and
bump patch for targets needing it.
* patches/binutils-2.17-rtems-20060815.diff: New file.
* configure.ac, gcc/build.add, gcc/target-gcc.add: Add bfin target
prior to merge. Add ability to disable libssp and libstdcxx-pch which
apparently are required to build the Blackfin port.
* patches/binutils-2.17-rtems-bfin-20060810.diff,
patches/gcc-4.1.1-bfinrtems-20060810a.diff,
patches/gdb-6.5-bfinrtems-20060810a.diff,
patches/newlib-1.14.0-bfinrtems-20060810a.diff,
rtems4.7/bfin/.cvsignore, rtems4.7/bfin/Makefile.am,
rtems4.7/bfin/binutils-sources.add, rtems4.7/bfin/gcc-sources.add,
rtems4.7/bfin/gdb-sources.add: New files.
* .cvsignore: Add INSTALL.
* patches/gcc-core-4.1.1-rtems-20060720.diff:
Added patch to fix GCC bug PR28400.
* configure.ac, rtems4.7/Makefile.am, rtems4.7/arm/Makefile.am,
rtems4.7/arm/gdb-sources.add, rtems4.7/avr/Makefile.am,
rtems4.7/avr/gdb-sources.add, rtems4.7/h8300/Makefile.am,
rtems4.7/h8300/gdb-sources.add, rtems4.7/i386/Makefile.am,
rtems4.7/i386/gdb-sources.add, rtems4.7/m68k/Makefile.am,
rtems4.7/m68k/gdb-sources.add, rtems4.7/mips/Makefile.am,
rtems4.7/mips/gdb-sources.add, rtems4.7/powerpc/Makefile.am,
rtems4.7/powerpc/gdb-sources.add, rtems4.7/sh/Makefile.am,
rtems4.7/sh/gdb-sources.add, rtems4.7/sparc/Makefile.am,
rtems4.7/sparc/gdb-sources.add, rtems4.7/tic4x/gdb-sources.add:
Updated to gdb 6.5
* patches/gdb-6.5-rtems-20060713.diff, rtems4.7/mipstx39/.cvsignore,
rtems4.7/mipstx39/Makefile.am, rtems4.7/mipstx39/gdb-sources.add: New files.
* rtems4.7/arm/gdb-sources.add, rtems4.7/avr/gdb-sources.add,
rtems4.7/h8300/gdb-sources.add, rtems4.7/i386/gdb-sources.add,
rtems4.7/m68k/gdb-sources.add, rtems4.7/mips/gdb-sources.add,
rtems4.7/powerpc/gdb-sources.add, rtems4.7/sh/gdb-sources.add,
Update gdb to use newer patch. This lets sparc build simulator and
mips build at all.
* patches/gdb-6.4-rtems-20060712.diff: New file.
