Sprout from rtems-4-7-branch 2007-03-05 20:53:27 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2007-03-05 Joel Sherrill <joel@OARcorp.com>'
Delete:
Makefile.maint
contrib/apt-conf/.cvsignore
contrib/apt-conf/COPYING
contrib/apt-conf/ChangeLog
contrib/apt-conf/INSTALL
contrib/apt-conf/Makefile.am
contrib/apt-conf/README
contrib/apt-conf/configure.ac
contrib/apt-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458
contrib/apt-conf/rtems-apt-conf.spec.in
contrib/apt-conf/sources.list.d/rtems-4.6.list
contrib/apt-conf/sources.list.d/rtems-4.7.list
contrib/apt-conf/vendors.list.d/rtems.list
contrib/crossrpms/.cvsignore
contrib/crossrpms/AUTHORS
contrib/crossrpms/COPYING
contrib/crossrpms/ChangeLog
contrib/crossrpms/Makefile.am
contrib/crossrpms/NEWS
contrib/crossrpms/README
contrib/crossrpms/TODO
contrib/crossrpms/acinclude.m4
contrib/crossrpms/autotools/.cvsignore
contrib/crossrpms/autotools/Makefile.am
contrib/crossrpms/autotools/autoconf.add
contrib/crossrpms/autotools/autoconf.am
contrib/crossrpms/autotools/automake.add
contrib/crossrpms/autotools/automake.am
contrib/crossrpms/autotools/target-autoconf.add
contrib/crossrpms/autotools/target-automake.add
contrib/crossrpms/binutils/.cvsignore
contrib/crossrpms/binutils/base-binutils.add
contrib/crossrpms/binutils/binutils.add
contrib/crossrpms/binutils/build.add
contrib/crossrpms/binutils/install.add
contrib/crossrpms/binutils/prep.add
contrib/crossrpms/binutils/rpm-install.add
contrib/crossrpms/binutils/target-binutils.add
contrib/crossrpms/bootstrap
contrib/crossrpms/common/clean.add
contrib/crossrpms/common/common.add
contrib/crossrpms/configure.ac
contrib/crossrpms/gcc/base-g77.add
contrib/crossrpms/gcc/base-gcc.add
contrib/crossrpms/gcc/base-gcj.add
contrib/crossrpms/gcc/base-gfortran.add
contrib/crossrpms/gcc/base-gnat.add
contrib/crossrpms/gcc/base-newlib.add
contrib/crossrpms/gcc/build.add
contrib/crossrpms/gcc/gccnewlib.add
contrib/crossrpms/gcc/install.add
contrib/crossrpms/gcc/prep.add
contrib/crossrpms/gcc/rpm-install.add
contrib/crossrpms/gcc/target-c++.add
contrib/crossrpms/gcc/target-g77.add
contrib/crossrpms/gcc/target-gcc.add
contrib/crossrpms/gcc/target-gcj.add
contrib/crossrpms/gcc/target-gfortran.add
contrib/crossrpms/gcc/target-gnat.add
contrib/crossrpms/gcc/target-newlib.add
contrib/crossrpms/gcc/target-objc.add
contrib/crossrpms/gdb/base-gdb.add
contrib/crossrpms/gdb/build.add
contrib/crossrpms/gdb/gdb.add
contrib/crossrpms/gdb/install.add
contrib/crossrpms/gdb/prep.add
contrib/crossrpms/gdb/rpm-install.add
contrib/crossrpms/gdb/target-gdb.add
contrib/crossrpms/mkspec.am
contrib/crossrpms/patches/binutils-2.16.1-rtems-20050708.diff
contrib/crossrpms/patches/binutils-2.17-rtems4.7-20061021.diff
contrib/crossrpms/patches/gcc-core-4.0.3-rtems-20060822.diff
contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff
contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff
contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff
contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.7-20070102.diff
contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.7-20070216.diff
contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff
contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff
contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff
contrib/crossrpms/patches/gdb-6.6-rtems4.7-20070218.diff
contrib/crossrpms/patches/gdb-6.6-rtems4.7-20070222.diff
contrib/crossrpms/patches/newlib-1.14.0-rtems4.7-20061019.diff
contrib/crossrpms/patches/newlib-1.15.0-rtems4.7-20070208.diff
contrib/crossrpms/rtems4.7/.cvsignore
contrib/crossrpms/rtems4.7/Makefile.am
contrib/crossrpms/rtems4.7/arm/.cvsignore
contrib/crossrpms/rtems4.7/arm/Makefile.am
contrib/crossrpms/rtems4.7/arm/binutils-sources.add
contrib/crossrpms/rtems4.7/arm/gcc-sources.add
contrib/crossrpms/rtems4.7/arm/gdb-sources.add
contrib/crossrpms/rtems4.7/avr/.cvsignore
contrib/crossrpms/rtems4.7/avr/Makefile.am
contrib/crossrpms/rtems4.7/avr/binutils-sources.add
contrib/crossrpms/rtems4.7/avr/gcc-sources.add
contrib/crossrpms/rtems4.7/avr/gdb-sources.add
contrib/crossrpms/rtems4.7/binutils.am
contrib/crossrpms/rtems4.7/gcc-prep.add
contrib/crossrpms/rtems4.7/gcc.am
contrib/crossrpms/rtems4.7/gdb.am
contrib/crossrpms/rtems4.7/h8300/.cvsignore
contrib/crossrpms/rtems4.7/h8300/Makefile.am
contrib/crossrpms/rtems4.7/h8300/binutils-sources.add
contrib/crossrpms/rtems4.7/h8300/gcc-sources.add
contrib/crossrpms/rtems4.7/h8300/gdb-sources.add
contrib/crossrpms/rtems4.7/i386/.cvsignore
contrib/crossrpms/rtems4.7/i386/Makefile.am
contrib/crossrpms/rtems4.7/i386/binutils-sources.add
contrib/crossrpms/rtems4.7/i386/gcc-sources.add
contrib/crossrpms/rtems4.7/i386/gdb-sources.add
contrib/crossrpms/rtems4.7/m68k/.cvsignore
contrib/crossrpms/rtems4.7/m68k/Makefile.am
contrib/crossrpms/rtems4.7/m68k/binutils-sources.add
contrib/crossrpms/rtems4.7/m68k/gcc-sources.add
contrib/crossrpms/rtems4.7/m68k/gdb-sources.add
contrib/crossrpms/rtems4.7/mips/.cvsignore
contrib/crossrpms/rtems4.7/mips/Makefile.am
contrib/crossrpms/rtems4.7/mips/binutils-sources.add
contrib/crossrpms/rtems4.7/mips/gcc-sources.add
contrib/crossrpms/rtems4.7/mips/gdb-sources.add
contrib/crossrpms/rtems4.7/mipstx39/.cvsignore
contrib/crossrpms/rtems4.7/mipstx39/Makefile.am
contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add
contrib/crossrpms/rtems4.7/powerpc/.cvsignore
contrib/crossrpms/rtems4.7/powerpc/Makefile.am
contrib/crossrpms/rtems4.7/powerpc/binutils-sources.add
contrib/crossrpms/rtems4.7/powerpc/gcc-sources.add
contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add
contrib/crossrpms/rtems4.7/sh/.cvsignore
contrib/crossrpms/rtems4.7/sh/Makefile.am
contrib/crossrpms/rtems4.7/sh/binutils-sources.add
contrib/crossrpms/rtems4.7/sh/gcc-sources.add
contrib/crossrpms/rtems4.7/sh/gdb-sources.add
contrib/crossrpms/rtems4.7/sparc/.cvsignore
contrib/crossrpms/rtems4.7/sparc/Makefile.am
contrib/crossrpms/rtems4.7/sparc/binutils-sources.add
contrib/crossrpms/rtems4.7/sparc/gcc-sources.add
contrib/crossrpms/rtems4.7/sparc/gdb-sources.add
contrib/crossrpms/specstrip
contrib/mingw/.cvsignore
contrib/mingw/AUTHORS
contrib/mingw/COPYING
contrib/mingw/ChangeLog
contrib/mingw/README
contrib/mingw/build-exes.sh
contrib/mingw/build-rpms.sh
contrib/mingw/build.sh
contrib/mingw/rtems-license.rtf
contrib/mingw/rtems-tools.nsi
contrib/mingw/rtems.ini
contrib/mingw/rtems_logo.bmp
contrib/mingw/targets
contrib/repo-conf/.cvsignore
contrib/repo-conf/AUTHORS
contrib/repo-conf/COPYING
contrib/repo-conf/ChangeLog
contrib/repo-conf/INSTALL
contrib/repo-conf/Makefile.am
contrib/repo-conf/NEWS
contrib/repo-conf/README
contrib/repo-conf/aclocal/version.m4
contrib/repo-conf/apt/sources.list.d/.cvsignore
contrib/repo-conf/apt/sources.list.d/rtems.list.in
contrib/repo-conf/apt/vendors.list.d/rtems.list
contrib/repo-conf/configure.ac
contrib/repo-conf/gpg/gpg-pubkey-69ce4a83-44cc2b30
contrib/repo-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458
contrib/repo-conf/rtems-repo-conf.spec.in
contrib/repo-conf/yum.repos.d/.cvsignore
contrib/repo-conf/yum.repos.d/rtems.repo.in
contrib/rtemsrpms/.cvsignore
contrib/rtemsrpms/AUTHORS
contrib/rtemsrpms/COPYING
contrib/rtemsrpms/ChangeLog
contrib/rtemsrpms/INSTALL
contrib/rtemsrpms/Makefile.am
contrib/rtemsrpms/NEWS
contrib/rtemsrpms/README
contrib/rtemsrpms/bootstrap
contrib/rtemsrpms/configure.ac
contrib/rtemsrpms/rtems.spec.in
testsuites/samples/base_sp/.cvsignore
* Makefile.am, gpg/gpg-pubkey-eac29b6f-3fe1f458, ChangeLog,
vendors.list.d/rtems.list, sources.list.d/rtems-4.6.list,
sources.list.d/rtems-4.7.list, configure.ac, .cvsignore, COPYING,
rtems-apt-conf.spec.in, INSTALL: New.
