path: root/configure (follow)
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-24/+24
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Added "done" to end of list of BSPs found.Joel Sherrill1998-01-151-1/+1
* Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill1998-01-151-21/+32
| | | | | | | configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
* Made --enable-gcc28 the default.Joel Sherrill1997-12-221-1/+1
* Added size_rtems as a generated file.Joel Sherrill1997-12-221-0/+2
* Changed RTEMS_BSP to RTEMS_BSP_LIST.Joel Sherrill1997-12-161-24/+23
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-25/+33
* Redid hwapi makefile search to remove need for -follow option to find.Joel Sherrill1997-12-061-39/+139
| | | | Avoid generating Makefiles for KA9Q and C++ when they are disabled.
* Added better/more correct support for Linux and Solaris simulators.Joel Sherrill1997-12-041-23/+41
* Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API relatedJoel Sherrill1997-12-011-9/+9
| | | | Makefiles would be properly generated.
* Even more cleanup to make sure all the --enable/disable options avoidJoel Sherrill1997-12-011-77/+108
| | | | | | | generating Makefiles where possible. Added code to make sure make/custom file and bsp directory exist for configured bsps. This code also accounts for "aliased" BSPs.
* Serious cleanup to reduce the number of explicitly listed Makefiles,Joel Sherrill1997-11-301-1005/+352
| | | | | eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated.
* Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automaticallyJoel Sherrill1997-11-291-290/+226
| | | | generate the list of Makefiles in the configure script.
* Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generateJoel Sherrill1997-11-181-207/+1153
| | | | the information in the make/os/XYZ.cfg files using autoconf.
* Added TOD code for MVME162 BSP from Katsutoshi Shibuya.Joel Sherrill1997-10-231-6/+7
* Added termios test.Joel Sherrill1997-10-231-7/+8
* Removed duplicate listing of install in MTARGETS.Joel Sherrill1997-09-211-6/+7
| | | | Add monitor test.
* Use own pdir option was reversed.Joel Sherrill1997-08-261-2/+2
* Added ppc-rtems as alternative name.Joel Sherrill1997-08-041-31/+53
| | | | | Moved files around in list of Makefile's to better support --disable-tests option.
* Corrected typo where "+ " was pasted in from another window.Joel Sherrill1997-08-011-12/+16
| | | | Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-8/+54
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* Added mvme162lx bsp configuration.Joel Sherrill1997-07-091-7/+10
| | | | M68040 FPSP was already part of the tree but was not being built.
* added ka9q stackJoel Sherrill1997-05-271-6/+30
* KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1997-05-231-30/+6
* updated to correct problem in decoding arguments provided to configure.Joel Sherrill1997-05-221-6/+22
* Added support for Hardware API. This will be distributed as a separateJoel Sherrill1997-04-221-7/+60
| | | | component which can be loaded on top of the RTEMS source tree.
* Corrected spelling of --enable-gcc28 argumentJoel Sherrill1997-04-181-3/+4
* Modifications to add --enable-libcdir and --enable-gcc28. TheseJoel Sherrill1997-04-181-6/+34
| | | | | trip options which allow the RTEMS makefile structure to support both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
* Added gen68360_040.Joel Sherrill1997-04-171-1/+1
* Rate monotonic period and cpu usage monitor libraries and tests added.Joel Sherrill1997-04-091-6/+12
* Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1997-04-091-6/+27
| | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
* updated to put bsps in alphabetical orderJoel Sherrill1997-04-071-4/+9
* disabled posix api for the no_cpu-rtems configuration in configure.inJoel Sherrill1997-04-021-2/+3
| | | | and regenerated configure.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+1631
