path: root/configure (follow)
* Bare bsp patch from Chris Johns and regenerated files.Joel Sherrill1998-06-251-6/+6
* Added freebsd support from Dario Alcocer <alcocer@connectnet.com>.Joel Sherrill1998-06-181-66/+72
* Regenerated aclocal and configure after cleaning up the check thatJoel Sherrill1998-06-041-67/+40
| | | | a BSP source directory was present to eliminate a chunk of redundant code.
* ppc-rtems is now an alias for powerpc-rtems.Joel Sherrill1998-06-031-2/+2
* Regenerated.Joel Sherrill1998-05-271-48/+47
* hppa1.1 -> hppa1_1 remapping crept back in somehow -- gona again.Joel Sherrill1998-05-221-83/+82
| | | | | | | Bare BSP is now only enabled when explicitly specified. Bare BSP options and variables are clearly named so as to be obviously BSP specific. This should avoid conflicts.
* Added bare bsp from Chris Johns <cjohns@plessey.com.au>.Joel Sherrill1998-05-211-97/+171
* Regenerated.Joel Sherrill1998-05-211-234/+157
* Support bsp_specs style building for linux and solaris. Improved C++Joel Sherrill1998-05-181-102/+85
| | | | support.
* Fixed bug where posix tests were not being enabled.Joel Sherrill1998-04-271-1/+1
* Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵Joel Sherrill1998-04-141-73/+79
| | | | gcc-target-default.cfg
* Patch from Samuel Tardieu <sam@inf.enst.fr> so the messages printedJoel Sherrill1998-04-031-4/+4
| | | | followed GNU conventions.
* Renamed hppa1_1 to hppa1.1Joel Sherrill1998-03-231-74/+71
* renamed ppc to powerpcJoel Sherrill1998-03-231-74/+71
* *** empty log message ***Joel Sherrill1998-03-231-101/+67
* Fixed RTEMS_PROG_CC_WORKS and RTEMS_PROG_CXX_WORKS so they couldJoel Sherrill1998-03-211-68/+99
| | | | successfully work on powerpc-rtems and hppa1.1-rtems.
* Patch from Ralf Corsepius to properly detect that Cygwin32 does notJoel Sherrill1998-03-201-66/+75
| | | | support the -pipe option on the compiler.
* Updated so test tools are installed even when --disable-tests isJoel Sherrill1998-02-191-20/+21
| | | | specified. Otherwise a target specific runtest is not installed.
* Ralf Corsepius pushing us farther down the autconf path:Joel Sherrill1998-02-171-0/+2
| | | | | | | | | | "Ladies and Gentlement, we proudly present: a roughly hacked autoconf-ed rtems-glom.in" (:-) BTW, to follow up to the discussion about installation points, rtems-glom in its current shape is an ideal example of a target dependent file. If bsp-specific configure-scripts would exist, it might also be a bsp-dependent file that contains RTEMS_BSP hard-coded (by configure) into it.
* Update from Ralf Corsepius:Joel Sherrill1998-02-171-120/+990
| | | | | | | | | | | | Yep, I have a bunch of bug-fixes and additions pending (Yet another monster patch, ... I can hear you scream :-). 1) configure.in : one AC_CONFIG_HEADER(...) line too much. 5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as gnu-programs use "cxx" to specify C++ specific configure options, while cpp is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf internally uses $CXX),
* Fixed hppa1.1 configuration.Joel Sherrill1998-02-111-3/+3
* Removed special ix86-rtems stanza.Joel Sherrill1998-02-041-32/+29
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-22/+21
* configure.inJoel Sherrill1998-01-301-16/+111
* Reverted change ...Joel Sherrill1998-01-221-2/+2
* Corrected/simplified setting of RTEMS_ROOT.Joel Sherrill1998-01-221-2/+2
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-211-37/+94
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Fixed libhwapi to reflect eeprom to non volatile memory rename.Joel Sherrill1998-01-201-16/+16
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-24/+24
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Added "done" to end of list of BSPs found.Joel Sherrill1998-01-151-1/+1
* Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill1998-01-151-21/+32
| | | | | | | configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
* Made --enable-gcc28 the default.Joel Sherrill1997-12-221-1/+1
* Added size_rtems as a generated file.Joel Sherrill1997-12-221-0/+2
* Changed RTEMS_BSP to RTEMS_BSP_LIST.Joel Sherrill1997-12-161-24/+23
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-25/+33
* Redid hwapi makefile search to remove need for -follow option to find.Joel Sherrill1997-12-061-39/+139
| | | | Avoid generating Makefiles for KA9Q and C++ when they are disabled.
* Added better/more correct support for Linux and Solaris simulators.Joel Sherrill1997-12-041-23/+41
* Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API relatedJoel Sherrill1997-12-011-9/+9
| | | | Makefiles would be properly generated.
* Even more cleanup to make sure all the --enable/disable options avoidJoel Sherrill1997-12-011-77/+108
| | | | | | | generating Makefiles where possible. Added code to make sure make/custom file and bsp directory exist for configured bsps. This code also accounts for "aliased" BSPs.
* Serious cleanup to reduce the number of explicitly listed Makefiles,Joel Sherrill1997-11-301-1005/+352
| | | | | eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated.
* Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automaticallyJoel Sherrill1997-11-291-290/+226
| | | | generate the list of Makefiles in the configure script.
* Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generateJoel Sherrill1997-11-181-207/+1153
| | | | the information in the make/os/XYZ.cfg files using autoconf.
* Added TOD code for MVME162 BSP from Katsutoshi Shibuya.Joel Sherrill1997-10-231-6/+7
* Added termios test.Joel Sherrill1997-10-231-7/+8
* Removed duplicate listing of install in MTARGETS.Joel Sherrill1997-09-211-6/+7
| | | | Add monitor test.
* Use own pdir option was reversed.Joel Sherrill1997-08-261-2/+2
* Added ppc-rtems as alternative name.Joel Sherrill1997-08-041-31/+53
| | | | | Moved files around in list of Makefile's to better support --disable-tests option.
* Corrected typo where "+ " was pasted in from another window.Joel Sherrill1997-08-011-12/+16
| | | | Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-8/+54
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* Added mvme162lx bsp configuration.Joel Sherrill1997-07-091-7/+10
| | | | M68040 FPSP was already part of the tree but was not being built.
