direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
enclose.
configuration successfully.
Added code to detect configuring macros and POSIX API at the same time.
There is no macro implementation for the POSIX API.
Avoid generating Makefiles for KA9Q and C++ when they are disabled.
Makefiles would be properly generated.
generating Makefiles where possible.
Added code to make sure make/custom file and bsp directory exist for
configured bsps. This code also accounts for "aliased" BSPs.
eliminated autoconf looking for commands which are unused, and reduce the
number of Makefiles generated.
generate the list of Makefiles in the configure script.
the information in the make/os/XYZ.cfg files using autoconf.
Add monitor test.
Moved files around in list of Makefile's to better support
--disable-tests option.
Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
M68040 FPSP was already part of the tree but was not being built.
component which can be loaded on top of the RTEMS source tree.
trip options which allow the RTEMS makefile structure to support
both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
and regenerated configure.
be resolved.
