1998-01-22 | Reverted change ... | Joel Sherrill | 1 | -2/+2 | |
1998-01-22 | Corrected/simplified setting of RTEMS_ROOT. | Joel Sherrill | 1 | -2/+2 | |
1998-01-21 | Added autoconf support for strerror/sys_errlist per Ralf Corsepius' | Joel Sherrill | 1 | -37/+94 | |
direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2. | |||||
1998-01-20 | Fixed libhwapi to reflect eeprom to non volatile memory rename. | Joel Sherrill | 1 | -16/+16 | |
1998-01-16 | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1 | -24/+24 | |
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
1998-01-15 | Added "done" to end of list of BSPs found. | Joel Sherrill | 1 | -1/+1 | |
1998-01-15 | Fixed code for --disable-rtems-inlines so that it would complete | Joel Sherrill | 1 | -21/+32 | |
configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API. | |||||
1997-12-22 | Made --enable-gcc28 the default. | Joel Sherrill | 1 | -1/+1 | |
1997-12-22 | Added size_rtems as a generated file. | Joel Sherrill | 1 | -0/+2 | |
1997-12-16 | Changed RTEMS_BSP to RTEMS_BSP_LIST. | Joel Sherrill | 1 | -24/+23 | |
1997-12-10 | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1 | -25/+33 | |
any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
1997-12-06 | Redid hwapi makefile search to remove need for -follow option to find. | Joel Sherrill | 1 | -39/+139 | |
Avoid generating Makefiles for KA9Q and C++ when they are disabled. | |||||
1997-12-04 | Added better/more correct support for Linux and Solaris simulators. | Joel Sherrill | 1 | -23/+41 | |
1997-12-01 | Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API related | Joel Sherrill | 1 | -9/+9 | |
Makefiles would be properly generated. | |||||
1997-12-01 | Even more cleanup to make sure all the --enable/disable options avoid | Joel Sherrill | 1 | -77/+108 | |
generating Makefiles where possible. Added code to make sure make/custom file and bsp directory exist for configured bsps. This code also accounts for "aliased" BSPs. | |||||
1997-11-30 | Serious cleanup to reduce the number of explicitly listed Makefiles, | Joel Sherrill | 1 | -1005/+352 | |
eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated. | |||||
1997-11-29 | Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automatically | Joel Sherrill | 1 | -290/+226 | |
generate the list of Makefiles in the configure script. | |||||
1997-11-18 | Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generate | Joel Sherrill | 1 | -207/+1153 | |
the information in the make/os/XYZ.cfg files using autoconf. | |||||
1997-10-23 | Added TOD code for MVME162 BSP from Katsutoshi Shibuya. | Joel Sherrill | 1 | -6/+7 | |
1997-10-23 | Added termios test. | Joel Sherrill | 1 | -7/+8 | |
1997-09-21 | Removed duplicate listing of install in MTARGETS. | Joel Sherrill | 1 | -6/+7 | |
Add monitor test. | |||||
1997-08-26 | Use own pdir option was reversed. | Joel Sherrill | 1 | -2/+2 | |
1997-08-04 | Added ppc-rtems as alternative name. | Joel Sherrill | 1 | -31/+53 | |
Moved files around in list of Makefile's to better support --disable-tests option. | |||||
1997-08-01 | Corrected typo where "+ " was pasted in from another window. | Joel Sherrill | 1 | -12/+16 | |
Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list. | |||||
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1 | -8/+54 | |
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
1997-07-09 | Added mvme162lx bsp configuration. | Joel Sherrill | 1 | -7/+10 | |
M68040 FPSP was already part of the tree but was not being built. | |||||
1997-05-27 | added ka9q stack | Joel Sherrill | 1 | -6/+30 | |
1997-05-23 | KA9Q stack removed prior to testing for 4.0.0 public release. | Joel Sherrill | 1 | -30/+6 | |
1997-05-22 | updated to correct problem in decoding arguments provided to configure. | Joel Sherrill | 1 | -6/+22 | |
1997-04-22 | Added support for Hardware API. This will be distributed as a separate | Joel Sherrill | 1 | -7/+60 | |
component which can be loaded on top of the RTEMS source tree. | |||||
1997-04-18 | Corrected spelling of --enable-gcc28 argument | Joel Sherrill | 1 | -3/+4 | |
1997-04-18 | Modifications to add --enable-libcdir and --enable-gcc28. These | Joel Sherrill | 1 | -6/+34 | |
trip options which allow the RTEMS makefile structure to support both gcc 2.7.2.2 and gcc 2.8 whenever that is released. | |||||
1997-04-17 | Added gen68360_040. | Joel Sherrill | 1 | -1/+1 | |
1997-04-09 | Rate monotonic period and cpu usage monitor libraries and tests added. | Joel Sherrill | 1 | -6/+12 | |
1997-04-09 | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1 | -6/+27 | |
was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | |||||
1997-04-07 | updated to put bsps in alphabetical order | Joel Sherrill | 1 | -4/+9 | |
1997-04-02 | disabled posix api for the no_cpu-rtems configuration in configure.in | Joel Sherrill | 1 | -2/+3 | |
and regenerated configure. | |||||
1997-04-01 | This set of changes is the build of what was required to convert to | Joel Sherrill | 1 | -0/+1631 | |
GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. |
