Bare BSP is now only enabled when explicitly specified.
Bare BSP options and variables are clearly named so as to be obviously
BSP specific. This should avoid conflicts.
support.
gcc-target-default.cfg
followed GNU conventions.
successfully work on powerpc-rtems and hppa1.1-rtems.
support the -pipe option on the compiler.
specified. Otherwise a target specific runtest is not installed.
"Ladies and Gentlement, we proudly present: a roughly hacked autoconf-ed
rtems-glom.in" (:-)
BTW, to follow up to the discussion about installation points, rtems-glom in
its current shape is an ideal example of a target dependent file. If
bsp-specific configure-scripts would exist, it might also be a bsp-dependent
file that contains RTEMS_BSP hard-coded (by configure) into it.
Yep, I have a bunch of bug-fixes and additions pending (Yet another monster
patch, ... I can hear you scream :-).
1) configure.in : one AC_CONFIG_HEADER(...) line too much.
5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as
gnu-programs use "cxx" to specify C++ specific configure options, while cpp
is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf
internally uses $CXX),
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
enclose.
configuration successfully.
Added code to detect configuring macros and POSIX API at the same time.
There is no macro implementation for the POSIX API.
Avoid generating Makefiles for KA9Q and C++ when they are disabled.
Makefiles would be properly generated.
generating Makefiles where possible.
Added code to make sure make/custom file and bsp directory exist for
configured bsps. This code also accounts for "aliased" BSPs.
eliminated autoconf looking for commands which are unused, and reduce the
number of Makefiles generated.
generate the list of Makefiles in the configure script.
the information in the make/os/XYZ.cfg files using autoconf.
Add monitor test.
Moved files around in list of Makefile's to better support
--disable-tests option.
Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
M68040 FPSP was already part of the tree but was not being built.
component which can be loaded on top of the RTEMS source tree.
