automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
all conflicts.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
it work.
Here is a cosmetic patch which corrects a few spelling problems in parts
written by me.
Apparently, I must have written these under the influence of ether (:-)
with libchip.
scripts (make/rtems.cfg)
Testing:
2. "make profile" doesn't work. It aborts when building host-tools
for embedded targets. I didn't yet have enough time to fix this
problem. AFAIS this problem is related to handling of
LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use
gcc for linking host applications, too. With profiling enabled
CFLAGS_PROFILE_V contains -pg and is used to compile, but
LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the
linker causing gcc to fail to link, because it can't resolve some
symbols introduced by compiling with -pg.
I am not sure if I can provide a patch for this - Ether it is trivial
to fix or requires basic work on host configuration ;-
Fixing this one was trivial - But hard to trace.
LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V,
if gcc is used for linking (What else should have been expected ?,
:-). The same problem was present for *_DEBUG_V, but apparently wasn't
noticed by anybody, because things didn't break, but were silently
ignored.
I fixed these problems by setting these flags in configure.in whenever
gcc is reported to be the host-compiler. For non-gcc host compilers
"make debug" and "make profile" now becomes the same as an ordinary
"make". This is a hack and addressing this problen could be more
sophisticated, but I don't think it gives much sense to support
compile variants for any host program (Who will ever try to
profile/debug host tools?). Therefore I don't think it's useful
to invest more effort into this problem.
test were suggested by Ian Taylor <ian@airs.com> and Joel did the
hard part of putting it in aclocal and editting all the offending
Makefiles and source code which could use this feature.
Here is another patch to hopefully enhance rtems' configuration.
Motivation: Try to support other c-compilers besides gcc (I tried to
build rtems under Solaris using sun's WSPro c-compiler).
Here is a couple of small patches concerning the host compiler
configuration, which fix/work-around the worst problems when using sun's
WSPro c-compiler.
* Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie.
gcc.cfg is generated by configure now.
* Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix).
* Add -g to host compiler flags only if configure reported -g to work
* Add -Wall to host compiler flags only if configure reported that the
host compiler is gcc (WSPro's cc chokes on -Wall).
* Some modifications to make/Makefile.in
* Adapted make/custom/default.cfg to the new location of gcc.cfg
BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS
etc.) which deserves to be cleaned up, IMO.
IMO, a similar patch should be applied to gcc-target-default.cfg
when the bare bsp was enabled without setting both --enable-cpu-model
and --enable-cpu-cflags.
of theses targets...
<corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port
is being configured on a system without System V IPC support. This
is an optional component on both FreeBSD and Linux systems. Most
Linux 2.x kernels ship with it enabled but it is still a real risk.
This test may have undesirable side-effects on some hosts. We will
address those conflicts as they arise.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
a BSP source directory was present to eliminate a chunk of redundant code.
Bare BSP is now only enabled when explicitly specified.
Bare BSP options and variables are clearly named so as to be obviously
BSP specific. This should avoid conflicts.
The breakdown:
* CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read
from autoconf's configuration cache (config.cache)
* If <target>-[gcc|g++] was not found while running configure,
the config macros tried to use other (wrong) compilers (e.g. cc).
* New RTEMS_PROG_CC macro (aclocal/prog-cc.m4).
* New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4)
* Moved a shell script fragment from configure.in to a
new m4-autoconf macro (New file: aclocal/tool-prefix.m4)
* Minor changes to configure.in
I tested it with linux/posix (native gcc/primary libc) and
sh-rtems/gensh1 on a linux host and didn't notice any bugs
related to the problems mentioned above. There seem to be
more bugs with the posix bsp, but I consider them minor as
the build run completed successfully. It is just too late
for me to attempt to fix them now.
support.
followed GNU conventions.
specified. Otherwise a target specific runtest is not installed.
"Ladies and Gentlement, we proudly present: a roughly hacked autoconf-ed
rtems-glom.in" (:-)
BTW, to follow up to the discussion about installation points, rtems-glom in
its current shape is an ideal example of a target dependent file. If
bsp-specific configure-scripts would exist, it might also be a bsp-dependent
file that contains RTEMS_BSP hard-coded (by configure) into it.
Yep, I have a bunch of bug-fixes and additions pending (Yet another monster
patch, ... I can hear you scream :-).
1) configure.in : one AC_CONFIG_HEADER(...) line too much.
5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as
gnu-programs use "cxx" to specify C++ specific configure options, while cpp
is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf
internally uses $CXX),
I am not sure if this is related to this problem, but here is an observation:
All config.sub scripts from rtems' intrastructure packages internally
transform i386-rtems into i386-pc-rtems
newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems
egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems
egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems
bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems
gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems
The only exception is rtems itself:
rtems/config.sub i386-rtems ---> i386-rtems
I am not sure if this influences i386-rtems + c++/posix, but this indicates
that rtems' config.sub script should to be updated.
To fix this, simply copying config.sub e.g. from egcs and removing all
i[3456]-rtems* case statement lines from configure.in should be sufficient.
BTW, from autoconf's point of view i386-pc-rtems is the correct target
conforming autoconf's naming conventions, but using i386-rtems for all
packages (infrastructure and rtems) should make no difference.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
enclose.
configuration successfully.
Added code to detect configuring macros and POSIX API at the same time.
There is no macro implementation for the POSIX API.
