when the bare bsp was enabled without setting both --enable-cpu-model
and --enable-cpu-cflags.
of theses targets...
<corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port
is being configured on a system without System V IPC support. This
is an optional component on both FreeBSD and Linux systems. Most
Linux 2.x kernels ship with it enabled but it is still a real risk.
This test may have undesirable side-effects on some hosts. We will
address those conflicts as they arise.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
a BSP source directory was present to eliminate a chunk of redundant code.
Bare BSP is now only enabled when explicitly specified.
Bare BSP options and variables are clearly named so as to be obviously
BSP specific. This should avoid conflicts.
The breakdown:
* CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read
from autoconf's configuration cache (config.cache)
* If <target>-[gcc|g++] was not found while running configure,
the config macros tried to use other (wrong) compilers (e.g. cc).
* New RTEMS_PROG_CC macro (aclocal/prog-cc.m4).
* New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4)
* Moved a shell script fragment from configure.in to a
new m4-autoconf macro (New file: aclocal/tool-prefix.m4)
* Minor changes to configure.in
I tested it with linux/posix (native gcc/primary libc) and
sh-rtems/gensh1 on a linux host and didn't notice any bugs
related to the problems mentioned above. There seem to be
more bugs with the posix bsp, but I consider them minor as
the build run completed successfully. It is just too late
for me to attempt to fix them now.
support.
followed GNU conventions.
specified. Otherwise a target specific runtest is not installed.
"Ladies and Gentlement, we proudly present: a roughly hacked autoconf-ed
rtems-glom.in" (:-)
BTW, to follow up to the discussion about installation points, rtems-glom in
its current shape is an ideal example of a target dependent file. If
bsp-specific configure-scripts would exist, it might also be a bsp-dependent
file that contains RTEMS_BSP hard-coded (by configure) into it.
Yep, I have a bunch of bug-fixes and additions pending (Yet another monster
patch, ... I can hear you scream :-).
1) configure.in : one AC_CONFIG_HEADER(...) line too much.
5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as
gnu-programs use "cxx" to specify C++ specific configure options, while cpp
is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf
internally uses $CXX),
I am not sure if this is related to this problem, but here is an observation:
All config.sub scripts from rtems' intrastructure packages internally
transform i386-rtems into i386-pc-rtems
newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems
egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems
egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems
bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems
gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems
The only exception is rtems itself:
rtems/config.sub i386-rtems ---> i386-rtems
I am not sure if this influences i386-rtems + c++/posix, but this indicates
that rtems' config.sub script should to be updated.
To fix this, simply copying config.sub e.g. from egcs and removing all
i[3456]-rtems* case statement lines from configure.in should be sufficient.
BTW, from autoconf's point of view i386-pc-rtems is the correct target
conforming autoconf's naming conventions, but using i386-rtems for all
packages (infrastructure and rtems) should make no difference.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
enclose.
configuration successfully.
Added code to detect configuring macros and POSIX API at the same time.
There is no macro implementation for the POSIX API.
Avoid generating Makefiles for KA9Q and C++ when they are disabled.
Makefiles would be properly generated.
generating Makefiles where possible.
Added code to make sure make/custom file and bsp directory exist for
configured bsps. This code also accounts for "aliased" BSPs.
eliminated autoconf looking for commands which are unused, and reduce the
number of Makefiles generated.
generate the list of Makefiles in the configure script.
the information in the make/os/XYZ.cfg files using autoconf.
Add monitor test.
Moved files around in list of Makefile's to better support
--disable-tests option.
Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
