path: root/configure.in (unfollow)
1997-04-07updated to put bsps in alphabetical orderJoel Sherrill1-2/+7
1997-04-02disabled posix api for the no_cpu-rtems configuration in configure.inJoel Sherrill1-0/+1
and regenerated configure.
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+560
