path: root/configure.in (unfollow)
1998-01-16Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1-0/+3
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
1998-01-15Added "done" to end of list of BSPs found.Joel Sherrill1-1/+1
1998-01-15Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill1-1/+12
configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
1997-12-22Made --enable-gcc28 the default.Joel Sherrill1-1/+1
1997-12-22Added size_rtems as a generated file.Joel Sherrill1-0/+1
1997-12-16Changed RTEMS_BSP to RTEMS_BSP_LIST.Joel Sherrill1-9/+4
1997-12-10Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1-3/+10
any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32).
1997-12-06Redid hwapi makefile search to remove need for -follow option to find.Joel Sherrill1-5/+21
Avoid generating Makefiles for KA9Q and C++ when they are disabled.
1997-12-04Added better/more correct support for Linux and Solaris simulators.Joel Sherrill1-1/+6
1997-12-01Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API relatedJoel Sherrill1-9/+9
Makefiles would be properly generated.
1997-12-01Even more cleanup to make sure all the --enable/disable options avoidJoel Sherrill1-22/+68
generating Makefiles where possible. Added code to make sure make/custom file and bsp directory exist for configured bsps. This code also accounts for "aliased" BSPs.
1997-11-30Serious cleanup to reduce the number of explicitly listed Makefiles,Joel Sherrill1-357/+82
eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated.
1997-11-29Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automaticallyJoel Sherrill1-255/+73
generate the list of Makefiles in the configure script.
1997-11-18Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generateJoel Sherrill1-93/+183
the information in the make/os/XYZ.cfg files using autoconf.
1997-10-23Added TOD code for MVME162 BSP from Katsutoshi Shibuya.Joel Sherrill1-0/+1
1997-10-23Added termios test.Joel Sherrill1-1/+2
1997-09-21Removed duplicate listing of install in MTARGETS.Joel Sherrill1-0/+1
Add monitor test.
1997-08-26Use own pdir option was reversed.Joel Sherrill1-2/+2
1997-08-04Added ppc-rtems as alternative name.Joel Sherrill1-25/+25
Moved files around in list of Makefile's to better support --disable-tests option.
1997-08-01Corrected typo where "+ " was pasted in from another window.Joel Sherrill1-2/+4
Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
1997-07-31Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1-2/+30
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
1997-07-09Added mvme162lx bsp configuration.Joel Sherrill1-1/+4
M68040 FPSP was already part of the tree but was not being built.
1997-05-27added ka9q stackJoel Sherrill1-0/+14
1997-05-23KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1-14/+0
1997-05-22updated to correct problem in decoding arguments provided to configure.Joel Sherrill1-4/+20
1997-04-22Added support for Hardware API. This will be distributed as a separateJoel Sherrill1-1/+45
component which can be loaded on top of the RTEMS source tree.
1997-04-18Corrected spelling of --enable-gcc28 argumentJoel Sherrill1-1/+1
1997-04-18Modifications to add --enable-libcdir and --enable-gcc28. TheseJoel Sherrill1-0/+12
trip options which allow the RTEMS makefile structure to support both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
1997-04-17Added gen68360_040.Joel Sherrill1-1/+1
1997-04-09Rate monotonic period and cpu usage monitor libraries and tests added.Joel Sherrill1-0/+4
1997-04-09Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1-0/+11
was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
1997-04-07updated to put bsps in alphabetical orderJoel Sherrill1-2/+7
1997-04-02disabled posix api for the no_cpu-rtems configuration in configure.inJoel Sherrill1-0/+1
and regenerated configure.
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+560
