path: root/configure.in (unfollow)
1997-07-09Added mvme162lx bsp configuration.Joel Sherrill1-1/+4
M68040 FPSP was already part of the tree but was not being built.
1997-05-27added ka9q stackJoel Sherrill1-0/+14
1997-05-23KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1-14/+0
1997-05-22updated to correct problem in decoding arguments provided to configure.Joel Sherrill1-4/+20
1997-04-22Added support for Hardware API. This will be distributed as a separateJoel Sherrill1-1/+45
component which can be loaded on top of the RTEMS source tree.
1997-04-18Corrected spelling of --enable-gcc28 argumentJoel Sherrill1-1/+1
1997-04-18Modifications to add --enable-libcdir and --enable-gcc28. TheseJoel Sherrill1-0/+12
trip options which allow the RTEMS makefile structure to support both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
1997-04-17Added gen68360_040.Joel Sherrill1-1/+1
1997-04-09Rate monotonic period and cpu usage monitor libraries and tests added.Joel Sherrill1-0/+4
1997-04-09Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1-0/+11
was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
1997-04-07updated to put bsps in alphabetical orderJoel Sherrill1-2/+7
1997-04-02disabled posix api for the no_cpu-rtems configuration in configure.inJoel Sherrill1-0/+1
and regenerated configure.
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+560
