path: root/configure.ac (follow)
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-021-2/+2
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2011-01-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-01-261-0/+6
| | | | | * configure.ac: Don't build tools/schedsim by default. Add --enable-schedsim (Default: disabled).
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-171-0/+1
| | | | | Add RTEMS Scheduler Simulator. * configure.ac: Add tools/schedsim.
* 2010-06-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-231-2/+2
| | | | * configure.ac: autoconf >= 2.65, automake >= 1.11.
* 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-171-1/+0
| | | | | * aclocal/enable-itron.m4: Remove. * configure.ac: Remove itron.
* s/AC_HELP/AS_HELP/.Ralf Corsepius2008-06-011-1/+1
* 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-021-1/+0
| | | | | * Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed.
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-021-1/+1
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-10-191-1/+0
| | | | | | | * configure.ac: Remove all macro implementations and use only the static inline. Static inline functions are now well supported so there is no reason for duplicate maintenance. * aclocal/enable-inlines.m4: Removed.
* changesRalf Corsepius2006-10-171-2/+2
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-1/+1
| | | | * configure.ac: Require automake > 1.9.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-171-1/+1
| | | | | | | * Makefile.am: DIST_SUBDIRS = $(SUBDIRS). Rework dist-hook. * configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP. * aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-0/+6
| | | | * configure.ac: RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools]).
* 2004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-131-1/+1
| | | | | | | | | * Makefile.am: Remove AUTOMAKE_FILES. Cleanup duplicate ACLOCAL_FILES. EXTRA_DIST += config-ml.in. DIST_SUBDIRS += make. Add dist-hook. * configure.ac: Add dist-bzip2 no-dist-gzip to AUTOMAKE_OPTIONS.
* 2004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-161-1/+1
| | | | | * configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-121-1/+1
| | | | * configure.ac: Requires automake >= 1.8.1.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-1/+0
| | | | | | | * configure.ac: Remove make/custom/Makefile. * Makefile.am: Cosmetics. * automake/compile.am: Remove compilation rules. Remove $(ARCH) directory generation.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-07-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-131-1/+1
| | | | | | * config.sub: Remove (Automatically added by automake, again). * bootstrap: Reflect change above. * configure.ac: Require automake >= 1.7.6.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-12/+1
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-251-7/+5
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-2/+2
| | | | * configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-291-1/+0
| | | | * configure.ac: Remove c/make.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-181-2/+2
| | | | | * acinclude.m4: Use AS_IF instead of if/then/else/endif. * configure.ac: Ditto.
* 2002-11-12 Joel Sherrill <joel@OARcorp.com>Ralf Corsepius2002-11-121-1/+0
| | | | * configure.ac: Remove make/compilers/Makefile.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-071-2/+1
| | | | | * configure.ac: Remove make/Templates/Makefile. * README.configure: Minor massaging.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-5/+3
| | | | * configure.ac: Activate cpukit. Remove references to c/src/exec.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-161-2/+0
| | | | | | | * automake/compile.am: Remove GCC272 support. Remove *.sh rule (unused). * configure.ac: Remove ENABLE_GCC28. Remove ENABLE_LIBCDIR.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-1/+1
| | | | | | | | * aclocal/version.m4: New file. * aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/ aclocal/version.m4. * bootstrap: Use aclocal/version.m4 instead of VERSION. * configure.ac: Use aclocal/version.m4 instead of VERSION.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-201-1/+8
| | | | | | | | * configure.ac: Add --enable-docs support. Add RTEMS_HOST_CONFIG_SUBDIRS(doc). Remove doc/Makefile. * Makefile.am: Add HOST_SUBDIRS to SUBDIRS. Remove doc from hard-coded SUBDIRS. * README.configure: Added a bit of information on this new option.
* 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-201-59/+12
| | | | | | | | | | | | | | | | | | | | * configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4. * aclocal/subdirs.m4: New file. * aclocal/multi.m4: New file, adopted from autoconf-2.52 w/ modifications. * aclocal/check-posix.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Reflect changes to other m4-macros. * aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE. Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs. Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir. * aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's OUTPUT_COMMANDS. * aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE. * aclocal/rtems-debug.m4: Minor cleanups. * aclocal/rtems-top.m4: Minor cleanups. * automake/compile.am: Further steps towards automake's rules.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+125
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
