path: root/configure.ac (follow)
* configure: Add subdir-objects to all automake flags.Chris Johns2018-04-111-1/+1
| | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
* Require the user to provide a BSP list when build SMP or MP.Chris Johns2018-04-101-1/+2
| | | | Close 3383.
* Generate an error if no valid gcc is found when configure runs.Chris Johns2018-04-101-1/+5
| | | | Close #3385.
* Remove make preinstallChris Johns2018-01-251-4/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* Remove texinfo format documentation. Replaced by Sphinx formatted documentation.Joel Sherrill2017-01-111-7/+0
| | | | closes #2812.
* DRVMGR: added driver manager to cpukit/libdrvmgrDaniel Hellstrom2015-04-171-0/+1
* Update bug report URLSebastian Huber2014-12-051-1/+1
* add --enable-paravirt to the configure optionsPhilipp Eppelt2013-11-271-0/+1
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+2
* Remove CVS-Ids.Ralf Corsépius2012-05-041-2/+0
* 2011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-171-7/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-041-3/+1
| | | | | * Makefile.am: Merge-in make/Makefile.am. * configure.ac: Reflect change above.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-021-2/+2
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2011-01-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-01-261-0/+6
| | | | | * configure.ac: Don't build tools/schedsim by default. Add --enable-schedsim (Default: disabled).
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-171-0/+1
| | | | | Add RTEMS Scheduler Simulator. * configure.ac: Add tools/schedsim.
* 2010-06-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-231-2/+2
| | | | * configure.ac: autoconf >= 2.65, automake >= 1.11.
* 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-171-1/+0
| | | | | * aclocal/enable-itron.m4: Remove. * configure.ac: Remove itron.
* s/AC_HELP/AS_HELP/.Ralf Corsepius2008-06-011-1/+1
* 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-021-1/+0
| | | | | * Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed.
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-021-1/+1
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-10-191-1/+0
| | | | | | | * configure.ac: Remove all macro implementations and use only the static inline. Static inline functions are now well supported so there is no reason for duplicate maintenance. * aclocal/enable-inlines.m4: Removed.
* changesRalf Corsepius2006-10-171-2/+2
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-1/+1
| | | | * configure.ac: Require automake > 1.9.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-171-1/+1
| | | | | | | * Makefile.am: DIST_SUBDIRS = $(SUBDIRS). Rework dist-hook. * configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP. * aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-0/+6
| | | | * configure.ac: RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools]).
* 2004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-131-1/+1
| | | | | | | | | * Makefile.am: Remove AUTOMAKE_FILES. Cleanup duplicate ACLOCAL_FILES. EXTRA_DIST += config-ml.in. DIST_SUBDIRS += make. Add dist-hook. * configure.ac: Add dist-bzip2 no-dist-gzip to AUTOMAKE_OPTIONS.
* 2004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-161-1/+1
| | | | | * configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-121-1/+1
| | | | * configure.ac: Requires automake >= 1.8.1.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-1/+0
| | | | | | | * configure.ac: Remove make/custom/Makefile. * Makefile.am: Cosmetics. * automake/compile.am: Remove compilation rules. Remove $(ARCH) directory generation.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-07-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-131-1/+1
| | | | | | * config.sub: Remove (Automatically added by automake, again). * bootstrap: Reflect change above. * configure.ac: Require automake >= 1.7.6.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-12/+1
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-251-7/+5
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-2/+2
| | | | * configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-291-1/+0
| | | | * configure.ac: Remove c/make.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-181-2/+2
| | | | | * acinclude.m4: Use AS_IF instead of if/then/else/endif. * configure.ac: Ditto.
* 2002-11-12 Joel Sherrill <joel@OARcorp.com>Ralf Corsepius2002-11-121-1/+0
| | | | * configure.ac: Remove make/compilers/Makefile.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-071-2/+1
| | | | | * configure.ac: Remove make/Templates/Makefile. * README.configure: Minor massaging.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-5/+3
| | | | * configure.ac: Activate cpukit. Remove references to c/src/exec.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-161-2/+0
| | | | | | | * automake/compile.am: Remove GCC272 support. Remove *.sh rule (unused). * configure.ac: Remove ENABLE_GCC28. Remove ENABLE_LIBCDIR.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-1/+1
| | | | | | | | * aclocal/version.m4: New file. * aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/ aclocal/version.m4. * bootstrap: Use aclocal/version.m4 instead of VERSION. * configure.ac: Use aclocal/version.m4 instead of VERSION.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-201-1/+8
| | | | | | | | * configure.ac: Add --enable-docs support. Add RTEMS_HOST_CONFIG_SUBDIRS(doc). Remove doc/Makefile. * Makefile.am: Add HOST_SUBDIRS to SUBDIRS. Remove doc from hard-coded SUBDIRS. * README.configure: Added a bit of information on this new option.
* 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-201-59/+12
| | | | | | | | | | | | | | | | | | | | * configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4. * aclocal/subdirs.m4: New file. * aclocal/multi.m4: New file, adopted from autoconf-2.52 w/ modifications. * aclocal/check-posix.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Reflect changes to other m4-macros. * aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE. Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs. Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir. * aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's OUTPUT_COMMANDS. * aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE. * aclocal/rtems-debug.m4: Minor cleanups. * aclocal/rtems-top.m4: Minor cleanups. * automake/compile.am: Further steps towards automake's rules.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+125
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
