* Makefile.am: Merge-in make/Makefile.am.
* configure.ac: Reflect change above.
* configure.ac: Don't build tools/schedsim by default.
Add --enable-schedsim (Default: disabled).
Add RTEMS Scheduler Simulator.
* configure.ac: Add tools/schedsim.
* configure.ac: autoconf >= 2.65, automake >= 1.11.
* aclocal/enable-itron.m4: Remove.
* configure.ac: Remove itron.
* Makefile.maint, configure.ac, release_support: Remove RDBG.
* aclocal/enable-rdbg.m4: Removed.
* configure.ac: Remove all macro implementations and use only the
static inline. Static inline functions are now well supported so
there is no reason for duplicate maintenance.
* aclocal/enable-inlines.m4: Removed.
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS).
Rework dist-hook.
* configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP.
* aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* configure.ac: RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools]).
* Makefile.am: Remove AUTOMAKE_FILES.
Cleanup duplicate ACLOCAL_FILES.
EXTRA_DIST += config-ml.in.
DIST_SUBDIRS += make.
Add dist-hook.
* configure.ac: Add dist-bzip2 no-dist-gzip to AUTOMAKE_OPTIONS.
* configure.ac: Require automake >= 1.8.2.
* aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* configure.ac: Requires automake >= 1.8.1.
* configure.ac: Remove make/custom/Makefile.
* Makefile.am: Cosmetics.
* automake/compile.am: Remove compilation rules.
Remove $(ARCH) directory generation.
* config.sub: Remove (Automatically added by automake, again).
* bootstrap: Reflect change above.
* configure.ac: Require automake >= 1.7.6.
* configure.ac: Remove "BLEEDING EDGE" warning.
Put docs into RTEMS_BUILD_CONFIG_SUBDIRS.
* acinclude.m4: Add AC_PREREQ(2.57).
Major overhaul (PR 412).
* aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM.
* aclocal/gcc-isystem.m4: New.
* Makefile.am: Add aclocal/gcc-isystem.m4.
* configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* configure.ac: Remove c/make.
* acinclude.m4: Use AS_IF instead of if/then/else/endif.
* configure.ac: Ditto.
* configure.ac: Remove make/compilers/Makefile.
* configure.ac: Remove make/Templates/Makefile.
* README.configure: Minor massaging.
* configure.ac: Activate cpukit. Remove references to c/src/exec.
* automake/compile.am: Remove GCC272 support.
Remove *.sh rule (unused).
Remove ENABLE_LIBCDIR.
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add --enable-docs support. Add
RTEMS_HOST_CONFIG_SUBDIRS(doc). Remove doc/Makefile.
* Makefile.am: Add HOST_SUBDIRS to SUBDIRS. Remove doc from
hard-coded SUBDIRS.
* README.configure: Added a bit of information on this new option.
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
* configure.in: Remove.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* configre.in: Fix AM_INIT_AUTOMAKE.
* aclocal/bsp-arg-enable.m4: Extend comments.
* aclocal/check-bsps.m4: Remove extraneous comments, add test -d in
the default clause.
* aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b).
* aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use
$host instead of $target (BUG-FIX).
* configure.in: Use $target and $host instead of $target_alias and
$host_alias (autoconf-2.49b).
* aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX)
* aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX)
NOTES:
* autoconf-2.49b depredicates using changequotes.
* The changes to configure.in are due to cleanups in
autoconf-2.49b's implemention of canonicalization. With
autoconf-2.1x it wasn't always clear, when to use $xxx or
$xxx_alias. Now this is clear.
* configure.in: New, Cygnus/GNU style configuration.
* Makefile.am: Add macros/, reflect new configure.in,
ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros
* automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION.
* automake/lib.am: Remove RTEMS_CANONICALIZATION.
* macros/tool-prefix.m4: Remove.
* macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS.
* macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting
RTEMS_ROOT.
* macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode-
* macros/multilib.m4: Various minor fixes.
* macros/project-root.m4: Remove setting PROJECT_TOPdir,
PROJECT_ROOT, RTEMS_ROOT.
* macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS;
Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
cpuopts.h.
to disabled.
problems at runtime.
that contains:
* Removes MKLIB
handling)
<corsepiu@faw.uni-ulm.de> which corrects some configuration
problems and cleans up a few Makefile.in's.
for RTEMS.
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
Fixes/Changes:
--target=no_cpu*rtems.
before adding :-)
toplevel/configure.in
files changed to RTEMS_CPU
<corsepiu@faw.uni-ulm.de>:
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
