* configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* configure.ac: Remove c/make.
* acinclude.m4: Use AS_IF instead of if/then/else/endif.
* configure.ac: Ditto.
* configure.ac: Remove make/compilers/Makefile.
* configure.ac: Remove make/Templates/Makefile.
* README.configure: Minor massaging.
* configure.ac: Activate cpukit. Remove references to c/src/exec.
* automake/compile.am: Remove GCC272 support.
Remove *.sh rule (unused).
Remove ENABLE_LIBCDIR.
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add --enable-docs support. Add
RTEMS_HOST_CONFIG_SUBDIRS(doc). Remove doc/Makefile.
* Makefile.am: Add HOST_SUBDIRS to SUBDIRS. Remove doc from
hard-coded SUBDIRS.
* README.configure: Added a bit of information on this new option.
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
* configure.in: Remove.
