path: root/config.sub (follow)
* 2000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-271-165/+314
| | | | | | * config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
* 2000-08-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-111-1/+2
| | | | * config.sub: Added or16 and or32.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-1/+1
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Change suggested by Ralf Corsepius:Joel Sherrill1998-02-041-40/+276
| | | | | | | | | | | | | | | | | | | | | | | | | | I am not sure if this is related to this problem, but here is an observation: All config.sub scripts from rtems' intrastructure packages internally transform i386-rtems into i386-pc-rtems newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems The only exception is rtems itself: rtems/config.sub i386-rtems ---> i386-rtems I am not sure if this influences i386-rtems + c++/posix, but this indicates that rtems' config.sub script should to be updated. To fix this, simply copying config.sub e.g. from egcs and removing all i[3456]-rtems* case statement lines from configure.in should be sufficient. BTW, from autoconf's point of view i386-pc-rtems is the correct target conforming autoconf's naming conventions, but using i386-rtems for all packages (infrastructure and rtems) should make no difference.
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+3
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Modified to rezongize CPU-rtemsXYZ rather than just CPU-rtems.Joel Sherrill1997-11-181-9/+15
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+933
