path: root/config.sub (unfollow)
2013-05-27Update from automake-1.13.2.Ralf Corsépius1-30/+25
2012-12-19Update from automake-1.12.6.Ralf Corsépius1-2/+6
2012-11-21Update from automake-1.12.5.Ralf Corsépius1-7/+10
2012-10-09Import from automake-1.12.4.Ralf Corsépius1-5/+9
2012-07-19Update from automake-1.12.2.Ralf Corsépius1-1/+10
2012-04-26Update config.guess and config.subJoel Sherrill1-6/+13
2012-02-222012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsépius1-0/+1766
* .gitignore: Remove config.guess, config.sub, missing, install-sh. * config.guess, config.sub, missing, install-sh: New.
2003-07-132003-07-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1504/+0
* config.sub: Remove (Automatically added by automake, again). * bootstrap: Reflect change above. * configure.ac: Require automake >= 1.7.6.
2003-06-182003-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+1504
* config.sub: New from subversions to accomodate c4x/tic4x.
2003-03-25Merger from rtems-4-6-branch.Ralf Corsepius1-1492/+0
2003-03-11Merger from rtems-4-6-branch.Ralf Corsepius1-0/+1492
2001-09-212001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1356/+0
* bootstrap: remove/add automake added files. * .cvsignore: reflect changes to bootstrap.
2001-03-012001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-46/+74
* configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
2000-11-272000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-165/+314
* config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
2000-08-112000-08-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+2
* config.sub: Added or16 and or32.
2000-07-26Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill1-1/+1
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
1998-02-04Change suggested by Ralf Corsepius:Joel Sherrill1-40/+276
I am not sure if this is related to this problem, but here is an observation: All config.sub scripts from rtems' intrastructure packages internally transform i386-rtems into i386-pc-rtems newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems The only exception is rtems itself: rtems/config.sub i386-rtems ---> i386-rtems I am not sure if this influences i386-rtems + c++/posix, but this indicates that rtems' config.sub script should to be updated. To fix this, simply copying config.sub e.g. from egcs and removing all i[3456]-rtems* case statement lines from configure.in should be sufficient. BTW, from autoconf's point of view i386-pc-rtems is the correct target conforming autoconf's naming conventions, but using i386-rtems for all packages (infrastructure and rtems) should make no difference.
1998-01-16Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1-0/+3
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
1997-11-18Modified to rezongize CPU-rtemsXYZ rather than just CPU-rtems.Joel Sherrill1-9/+15
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+933
