path: root/config.guess (follow)
* 2000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-271-107/+700
| | | | | | * config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+2
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+693
