path: root/config.guess (unfollow)
1998-01-16Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1-0/+2
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+693
