path: root/config.guess (follow)
* Update from automake-1.13.3.Ralf Corsépius2013-06-181-65/+79
* Update from automake-1.13.2.Ralf Corsépius2013-05-271-18/+25
* Update from automake-1.12.5.Ralf Corsépius2012-11-211-2/+2
* Import from automake-1.12.4.Ralf Corsépius2012-10-091-4/+11
* Update from automake-1.12.2.Ralf Corsépius2012-07-191-2/+2
* Update config.guess and config.subJoel Sherrill2012-04-261-4/+12
* 2012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsépius2012-02-221-0/+1522
| | | | | * .gitignore: Remove config.guess, config.sub, missing, install-sh. * config.guess, config.sub, missing, install-sh: New.
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-271-1391/+0
| | | | * config.guess: No longer in CVS since installed by bootstrap.
* 2001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-03-011-113/+216
| | | | | | | | * configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
* 2000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-271-107/+700
| | | | | | * config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+2
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+693
