path: root/config-ml.in (unfollow)
2008-12-312008-12-31 Ralf Cors├ępius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* config-ml.in: Comment out arm/thumb exception (Add arm/thumb multilib).
2006-08-092006-08-09 Kolja Waschk <waschk@telos.de>Joel Sherrill1-0/+15
* config-ml.in: New port to Altera NIOS II.
2004-08-182004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-2/+2
PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'.
2003-10-232003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+11
* config-ml.in: Don't built multilib variant normal (-mn) for h8300-*-rtems*.
2003-07-152003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-15/+6
* config-ml.in: Partial sync with gcc-3.4's config-ml.in. Add "autoconf-2.5x unquoting" hack.
2003-03-25Merger from rtems-4-6-branch.Ralf Corsepius1-1/+4
2002-07-062002-07-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-248/+21
* config-ml.in: Imported from gcc-3.1. Change to match c/src/config-ml.in.
2002-07-06Initial revisionRalf Corsepius1-22/+248
2002-05-142002-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-247/+14
* config-ml.in: Take out arm and sh variants RTEMS does not support.
2001-12-182001-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+878
* config-ml.in: New file. Imported from gcc and modified for RTEMS.
